You will need to recirculate the blowoff valve back in front of the MAF sensor. I had to do that on my Audi when I ditched the K03 and swapped in a Borgwarner GM3 snail.
Correct. The MAF has already determined how much air is going to be sucked through the motor.. so to waste to the atmosphere will make a rich condition because the air the motor thought it was going to get has just vanished...but the fuel is still injected for that amount of air and may even cause the engine to stall after hi-revving and completely letting off the throttle... so says the internet..
Good work. So your runnin that same turbo from a merc. ? No leaks everything's good so far?
Started by toyspider81 Project Research and Build-Ups
Started by mudgrapler RC Rock Crawler Tech
Started by GhostMoney « 1 2 3 » Project Research and Build-Ups
Started by Tyler+Ashleys4runner For Trade or Barter!
Started by Nation Project Research and Build-Ups
