Author Topic: Dual cases popping out of gear  (Read 3368 times)
91 ex-cab
  • Turtle Points: -171
  • Male Posts: 1,660
  • Member since Mar '10
  • Honey Badger
« on: Oct 03, 2011, 11:43:54 PM »
 I need some help trouble shooting my duals. When I have the crawl box in hi, and the back case in 4 low the crawl box will pop out of hi into neutral randomly. I never have this problem when in low/low at all , only when i get into hi/low.   Also when I go to put the back case into 2wd  the shifter binds up and I have to push it pretty hard to get it to pop in, it does the same thing when going into 4 low( I have tried with the crawlbox in high/low/ and neutral but it still does it no matter what).
    I have drained the oil and it looked good with no metal shavings, and I have been told to check the detent springs because I might need hd ones.
yoshaleng
  • Turtle Points: 134
  • Male Posts: 1,258
  • Member since Jul '09
Re: Dual cases popping out of gear
« Reply #1 on: Oct 04, 2011, 12:10:20 AM »
check for your detent ball...
Nimyad
  • Turtle Points: -1
  • Male Posts: 1,138
  • Member since Sep '10
    • Buy me a cigar
« Reply #2 on: Oct 04, 2011, 09:33:40 AM »
I have the same problem but only when the crawl box is in low, then it'll pop into neutral under compression or on the flat, whether my rear case is in low or high doesn't matter
ajordan1975
  • Turtle Points: 8
  • Male Posts: 1,004
  • Member since Jun '07
  • i think i'm cool
« Reply #3 on: Oct 04, 2011, 09:40:10 AM »
My brothers is the same way.
Slolyfe
  • Turtle Points: -117
  • Male Posts: 2,048
  • Member since Aug '07
  • Heyo
« Reply #4 on: Oct 04, 2011, 09:41:00 AM »
I just went through that exact same thing, replace your detent balls, and up grade to the HD springs. It will cost you like 5 bucks.
You'll never take me alive
91 ex-cab [OP]
  • Male Posts: 1,660
  • Honey Badger
« Reply #5 on: Oct 05, 2011, 09:32:32 AM »
I take it there's no way around it, the cases have to be pulled? Iirc I need 2 springs for the back case and 1 for the crawl box?
Goldrush
  • Turtle Points: 145
  • Male Posts: 1,381
  • Member since Jan '10
  • wheelin!!
« Reply #6 on: Oct 05, 2011, 09:48:29 AM »
 :yesnod:
superyoat
  • Turtle Points: -4
  • Male Posts: 132
  • Member since May '10
« Reply #7 on: Oct 05, 2011, 12:58:48 PM »
mine did that a couple times put the marlin heavy duty shift spring in and problem solved
http://www.marlincrawler.com/hardware-tools/hardware/heavy-duty-shift-spring
1985 4runner. 4.3TBI, ford 9" rear w/detroit, toy front w/detroit, longfield shafts, alcan springs, dual cases.
Jagdverband44
  • Turtle Points: -1
  • Male Posts: 155
  • Member since Mar '07
« Reply #8 on: Oct 05, 2011, 03:54:50 PM »
Why is your crawl box in the front? You are putting so much torque through the shaft, suprised all of you have not have not blown bearings or snapped shafts. The shaft is torquing so much it is putting pressure for and aft on the shaft and moving the shift forks and thats why you are popping out of gear. Crawl box always goes in back!! HD detents are just a band aid and don't fix the actual problem.
I've got the most liftedest truck in town, that little jap truck done stand no chance gainst my Chevy. My Chevy gots a V8 more lift an bigger tires,and an exhaust system, whats yer tuna can got, a V4, and them tires look like they is offa Saturn Corulla. The dealer instulled my lift, so ya no its done right, you just try to foller me throo them rocks an see what a reel truck can do.
Nimyad
  • Turtle Points: -1
  • Male Posts: 1,138
    • Buy me a cigar
« Reply #9 on: Oct 05, 2011, 04:00:30 PM »
You know a crawl box is just the reduction housing for our transfer case right?
Slolyfe
  • Male Posts: 2,048
  • Heyo
« Reply #10 on: Oct 05, 2011, 08:22:03 PM »
I just pulled the crossmember and lowered them till I could reach the detent spring plugs.
91 ex-cab [OP]
  • Male Posts: 1,660
  • Honey Badger
« Reply #11 on: Oct 05, 2011, 09:16:55 PM »
Ok i'll do that, and my buddy was telling me to use a magnet to get the detent balls.
  So how exactly is the crawlbox going to work on the back? Since it is just a reduction unit it has no outputs, so basically it would just be in back free spinning with no drive or reduction.
Slolyfe
  • Male Posts: 2,048
  • Heyo
« Reply #12 on: Oct 05, 2011, 09:30:04 PM »
Yea a really small magnet, about the size of a pencil in diameter. I just got marlins HD springs and no more popping out.
rockin86runner
  • Turtle Points: -18
  • Male Posts: 871
  • Member since Nov '07
« Reply #13 on: Oct 05, 2011, 09:32:46 PM »
sweet mine just started doing this last run out ordering tomorrow
85 toy runner tons 4link front and rear ORIs 42 pitbulls
86 runner some other things  pained orange STOLEN REWARD IF FOUND
70 cj-5 renegade1 buick 231 v-6 t-18 dana20 dana 30,44 32in BFG at
 :usa: USN SEABEE EO2 SCW .....We Build.We Fight.We Defend....Hoo-Rah  GOD BLESS OUR TROOPS :usa:
Slolyfe
  • Male Posts: 2,048
  • Heyo
« Reply #14 on: Oct 05, 2011, 09:33:58 PM »
Do twin sticks now if you haven't pulled the interlocking pin!
91 ex-cab [OP]
  • Male Posts: 1,660
  • Honey Badger
« Reply #15 on: Oct 05, 2011, 09:37:06 PM »
How worth it would you say twin sticks are?  I'm trying to stay cheap on this but might end up doing a little upgrading with twin stick, and 30 spline outputs.
Slolyfe
  • Male Posts: 2,048
  • Heyo
« Reply #16 on: Oct 05, 2011, 09:40:53 PM »
Well the only reason I have twin-sticks is because I won them at a Round-up years ago and the only time I use them is to put the rig on the trailer. So I don't think they are worth the price. But it does make shifting the rear case easier...
fordh8r
  • Turtle Points: 850
  • Male Posts: 2,588
  • Member since Jan '07
  • when my toyota grows up it'll be just like my chevy!
« Reply #17 on: Oct 06, 2011, 09:08:42 AM »
I like having my twin sticks because you can have 2wd low so that you can steer better (if you have a locker in the front like I do) in the sections where 4wd isn't really needed and you still get to have the low range power.  :yupyup:
rockin86runner
  • Male Posts: 871
« Reply #18 on: Oct 06, 2011, 09:15:16 AM »
^ agreed i like to be able to take it out and be able to steer and in some sections be able to hall some balls
swapped89
  • Turtle Points: 270
  • Male Posts: 1,221
  • Member since Aug '09
  • Not all who wander...are lost
« Reply #19 on: Oct 06, 2011, 01:49:28 PM »
An you can do low range burnies to move the back end over. If needed
SAS 89 p/u 3.0 5speed, bobbed, locked, ready to play in the rocks. or wherever the pavement ends :)
http://board.marlincrawler.com/index.php?topic=61345.0
a wise man listens and observes more so than he opens his mouth.. and when he does it is valuable information....   (twistedtoy92)
Last post Dec 13, 2004, 09:29:19 PM
by Marlin
Last post Feb 22, 2005, 03:54:11 PM
by TOYJOETA
Last post Feb 16, 2006, 01:19:53 PM
by FIREBALL
Last post Aug 23, 2007, 11:04:47 PM
by Jud
Last post Sep 11, 2009, 10:10:05 PM
by kneedownnate
