crazy quick question
Started by 83yota, September 14, 2011, 03:48:07 PM
83yota
doesanyoneknowifthetrannybehindav-6isthesameasbehindthe4cyl(manual)?(secondgen)
i said it was quick
does any one know if the tranny behind a v-6 is the same as behind the 4cyl (manual)? (second gen)
santa cruz crawler
W 56 is what it could be ! The engine compartment should say w56. W54 but I know the w56 bolts up to the 22r 22re 22ret   And 20r
negative
the v6 uses a different tranny than the 4cyl
TURBO
Quote from: jimbo74 on September 14, 2011, 05:59:20 PM
negative
that's right v6 has a R-150, and the 4cyl has W-56,
ALTHO, the 4cyl Turbo has an R-151F witch is similar to the R-150, but with a lower first gear. 4.31 as compared to the V6's 3.83, and the 4cyl's W-56 at 3.93
the tail housing is also different as the R-151F bolts up to a RF1A gear drive transfercase, same as the W-56 but the R-151F is 23 spline output and the W is 21spline.
the R-150 found in the V-6 bolts up to the chain drive case
MY BUILDS: http://board.marlincrawler.com/index.php?topic=76463.0 :woohoo:
More than tread lightly, leave it like you were never there, nor anyone else.
I AM :screwy:!!!
Quote from: Hank Williams Jr. on September 19, 2008, 09:55:09 AM
"These dusty roads ain't streets of gold
But I'm a happy right where I'm at"
Quote from: Wermz84 on September 19, 2008, 09:55:09 AM
Marlin is like the Chuck Norris of the rock crawling world.
santa cruz crawler
Nice , I was not to sure but cool. Learn somethin today!
:thumb:
83yota
so how much lees is it? the reason i am asking is i am looking at buying a 94 4x4 runner that had a BAD enginge fire for 600 and trying to fuigure if it is worth it.
83yota
Shamb
depends on what your plans are for it..... you could swap in a 22RE and put in a W56... or you could swap in a 3.0 again and go with an R series tranny....
most will tell you that the 3.0's aren't very good engines... i'd agree..
problem is the 2nd gen is pretty heavy and that 22RE would probably be fighting to keep up.. whats your budget?   you could also go for the popular 3RZ swap.
plenty of power and aftermarket support.
83yota
the plan is to rip it down part it out (other than what i need) and scrap it
