Author Topic: Winch cables to the starter???????  (Read 2039 times)
sweetmeat
  • Turtle Points: -13
  • Member since Dec '08
  • Friends don't let friends join the sierra club
    • Wrecked4x4
« on: Sep 10, 2011, 12:40:15 PM »
I was wondering what you guys think. I have a warn 9.5ti winch mounted in the front of my truggy. I recently mounted 2 optima batteries in the rear of my truck. I was wondering if i can just run my winch cables like this. Positive to the starter and negative to the frame, instead of running 2 cables all the way to the rear of my truck. The warn manual says under full load the winch can pull up to 300amps. But i don't think it would damage the starter because the starter isn't cranking over. Or am i over thinking this and should i just run the lines to the back. What do you guys think??
A&G Motorsports Class 1 #1553 Crew Member
Wrecked4x4.com
Shamb
  • Raisin in the making..
  • Turtle Points: 133
  • Male Posts: 3,414
  • Proud Parent
Re: Winch cables to the starter???????
« Reply #1 on: Sep 10, 2011, 02:12:41 PM »
that's a damn good question, i would assume you can but i have no clue.... that would be good to know it will certainly save you some $
Gamera
  • Turtle Points: 218
  • Male Posts: 140
  • Member since Sep '09
« Reply #2 on: Sep 10, 2011, 03:36:08 PM »
 :shocking:
junya92toy
  • Turtle Points: -64
  • Male Posts: 1,500
  • Drinking me beer
« Reply #3 on: Sep 10, 2011, 04:55:22 PM »
So you want to only be able to use the winch when the starter is going?
IronClad
  • Turtle Points: 635
  • Male Posts: 2,284
  • Annihilation Fabrication
« Reply #4 on: Sep 10, 2011, 05:08:36 PM »
Thats not how it works
I have mine setup on my 22re like that and it works just fine. had it setup like that also on an older truck of mine for about 4 years and never had a problem on that truck either.
Do you need a Hammer?
Shamb
  • Male Posts: 3,414
  • Proud Parent
« Reply #5 on: Sep 10, 2011, 10:30:41 PM »
it's not going through any kind of relay, more or less power hits the starter then follows through to the winch.
Zs Confederate Toy
  • Male Posts: 1,146
  • Member since Mar '11
« Reply #6 on: Sep 11, 2011, 12:24:54 AM »
Have you ever grounded out the pos end of a starter with a wrench? It arcs, meaning there is constant power goin to it. There isnt a switch that turns the power on and off when the starter is engaged.
I dont see any reason that you couldnt connect it there. It would definitly save you the money to run the cable to your new batt location. Its at least worth a try
ZACH
87 Rock Rat X
80 SR5 The Shady Lady
Trail Junky
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #7 on: Sep 11, 2011, 03:23:43 AM »
Don't see it hurting anything, but personally I would run it direct to the batteries so as not to find out that it does the hard way.
sweetmeat [OP]
    • Wrecked4x4
« Reply #8 on: Sep 11, 2011, 10:52:56 AM »
I was thinkin the same thing. I'm sure it wouldn't hurt anything, I just havnt seen it done before. Though I'm sure it would work
Wrecked4x4.com
yotarunner85
  • Turtle Points: 6
  • Male Posts: 166
  • Member since Nov '09
  • San Diego, CA
« Reply #9 on: Sep 12, 2011, 05:22:01 PM »
X2
1985 Toyota 4Runner, BFG 35" MTs, 4" lift, Detroits lockers front & rear,5.29, V6 rear, rebuilt 22RE.
Last post Jan 28, 2007, 01:02:15 PM
by skyscraper
Last post May 18, 2007, 03:03:45 PM
by Mace
Last post Jun 19, 2007, 11:50:02 PM
by iNfErNaL
Last post May 07, 2009, 12:16:58 PM
by BLACKDOG
Last post Mar 12, 2011, 07:33:18 PM
by sacsogv
