full width HELP!!!!!!!!!
Started by 83yota, August 29, 2011, 09:03:06 PM
83yota
So i am going to run chevy full widths under my 90 runner. now the question I am needing answered is the SAS is 29" center to center. I measured the axle and if i do the springs 29" center to center it would put the spring on top of the pumpkin. So i need someone who has done this swap or has seen one close to let me know how or where to put these springs.
Shamb
why wouldn't you line them up w/ the frame rails?
if anything you'd want to move them outwards for stability... moving them in will give you flex but horrible results for REAL trail use.
Shamb
IronClad
Build a new cross member and do it right.. We've had people do that dumb :pokinit: and hack into the pumpkin and weld a plate on so they didnt have to build a new cross member and do it right. No its not 29" for fullwidth. Its 31.5 IIRC.  So build a hanger around that or.. buy one of these if you're lazy like me http://www.sky-manufacturing.com/new/detaproduct.php?id=184 and dont worry about it.
Annihilation  Fabrication
Do you need a Hammer?
83yota
So I looked at the sky kit. do i need to build the offset shackles also? this is turing out to not be a damn near free build anymore. :(
Shamb
yea probably, if your cross members wider then i'm sure the shackles @ the frame are going to have to compensate for the extended distance.
IronClad
you dont HAVE to if you dont want to have wider at the top shackle tubes. you can just make a setup for straight shackles and weld them to a plate to outboard them off the frame.
Shamb
Quoteyou can just make a setup for straight shackles and weld them to a plate to outboard them off the frame.
^ If you don't do this or something similar your springs are going to be inboard @ the frame rails (shackles) and your gonna have problems.  Like mad twisty spring flex  :D
83yota
lol. I just saw what sky offered to fix this problem. do you think running the springs in the same spot in the rear is cool? (leaf conversion)
IronClad
what do you mean in the same spot?
83yota
along the frame or do i need to make them offset also
IronClad
so.. they sit like a \ /  ? You need to make them straight..
83yota
no i would build new perches on the axle just want to make sure i am not going to miss anything.
IronClad
there is no room to build new perches on the axle
Shamb
you'd probably have the same problem in the rear as you would in the front. not sure what axles your running but if they're too far inward then they won't be doing much good for stability...
you can build a boxed in mount on the frame and do like a drop box in the rear. If you did a drop box i'd recomment cutting it into the back of the frame so it wouldn't increase height.
IronClad
i guess i misunderstood  his posts are a bit scattered lol
Rocksnail
in the rear all you need to do is weld on new spring perches on the axle
1993 4door  s10 Tahoe. 4.3 th350c duel toys w/4.7 rear, D60 front 5.13 welded. 14Bolt rear 5.13 mini spool,hydro assist, TG 5HD front springs, 63s out back. h2s with 39x14 17 Pit Bull Madd Dogs
83yota
thats is what i was asking. it seems that most of the stuff i am finding on this is done with links and coils and i am trying to stay as inexpensive as possible
