Author Topic: ATTEN MARLIN W56 Tranny wierdness  (Read 3102 times)
runninout
  • Turtle Points: 27
  • Male Posts: 16
  • Member since Feb '05
« on: Feb 05, 2005, 01:48:09 PM »
Hey Marlin, Just got a 87 runner w/ 233,000 mi W56-B tranny that has a hard time going into 1st, It will do into 1st with a little clutch manipulation, when I do get it in 1st and shift to 2nd sometimes it has a hard time gettin in to gear...all other gears have no problem engaging..also sometimes when I put it in nuetral it makes a clunking noise like it's still kind-of in gear.  When it's in any gear it drives fine with no noise or any wierdness.  I have already changed the shifter bushings and drained the old oil out and replaced it with 80/90 GL-5.  It seemed to make a difference, but did not completly stop the problem.  I have been told that the clutch could be suspect, but it does not slip at all...  could you shed some light in this???  Thanks!!!
Yea huh??? Should I bring my f@#kin tools
  • Turtle Points: 679
  • Member since Feb '03
  • Don't blame me, I didn't vote for this crap.
Re: ATTEN MARLIN W56 Tranny wierdness
« Reply #1 on: Feb 05, 2005, 07:33:06 PM »
Id suspect the pilot bearing.  They have a tendancy to go out and cause all sorts of issues such as youve described.
ezthere
  • Turtle Points: -11
  • Member since Feb '04
  • 85 4runner, worked 4.3L V6. 300HP.
« Reply #2 on: Feb 06, 2005, 03:39:12 AM »
How bout the syncro's ?  :dunno:
Chuck
Willy Mammoth
  • Male Posts: 4,252
  • Member since Nov '04
« Reply #3 on: Feb 06, 2005, 04:52:53 AM »
I think W/T has it. If the pilot bearing drags it keeps the input shaft turning and causing the syncros to work harder to stop the trans when sitting still. If you can shift it fine with the engine off I would check the pilot bearing.
runninout [OP]
  • Turtle Points: 27
  • Male Posts: 16
« Reply #4 on: Feb 06, 2005, 01:20:55 PM »
It will go into gear when the engine is off but maybe not as smooth as it should....
NC854Runner
  • Male Posts: 29
  • Member since Dec '04
    • 85 Toyota 4Runner
« Reply #5 on: Feb 06, 2005, 05:53:55 PM »
I would agree on the pilot bearing. I just changed my Master clutch cylinder, slave cylinder and all hard lines. Started have the same problems you are having. So I change out the clutch and bearings No problem now everything working fine right now. I keep changing things out I'm going to have a new 4Runner. :smack:
85 Toyota 4Runner EFI 4cyl 4x4
runninout [OP]
  • Turtle Points: 27
  • Male Posts: 16
« Reply #6 on: Feb 07, 2005, 04:53:36 PM »
thanks eveyone for the input This BBS rocks!!!
« Last Edit: Feb 07, 2005, 06:01:09 PM by runninout »
runninout [OP]
  • Turtle Points: 27
  • Male Posts: 16
« Reply #7 on: Feb 22, 2005, 02:38:46 PM »
well, the verdict is in..1st gear syncros... :smack:
Kurlee Daddee
  • Turtle Points: 50
  • Male Posts: 206
  • Member since Dec '05
  • Dank Daddee Krew
« Reply #8 on: Oct 06, 2006, 10:51:52 AM »
I have the same problem getting my W56 into first, but only when its cold. I have no other problems getting the tranny into any other gear. Just first. As soon as it warms up, 1st gear is not a problem. What do you guys think? The clutch feels okay. Not 100%, but decent. I did a tranny flush not too long ago and poured the right amount of fluid into the tranny. What do you guys suggest?
Kurlee Daddee
(THE ORIGINAL)
2005 Cadillac CTS-V
2003 Subaru WRX
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
« Reply #9 on: Oct 08, 2006, 10:51:21 PM »
What weight oil are you running in it?
              -Ronald Reagan
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
« Reply #10 on: Oct 08, 2006, 11:11:53 PM »
wow this is an old thread, lol
how is the fluid level? as well..... i know that after i do a flush of any kind, the level is good fro awhile, but always has a way of settling to less a little later on....
Kurlee Daddee
  • Turtle Points: 50
  • Male Posts: 206
  • Dank Daddee Krew
« Reply #11 on: Oct 09, 2006, 05:46:38 AM »
75 90w
I have no way of checking the fluid level since the fill plug is completely stripped and will not come out. I guess I can take out the shifter again and fill it a little more.
Kurlee Daddee
(THE ORIGINAL)
2005 Cadillac CTS-V
2003 Subaru WRX
Last post Aug 10, 2003, 11:23:25 AM
by rEdnECkwHeE1eR
Last post Aug 22, 2003, 06:48:54 PM
by rEdnECkwHeE1eR
Last post Oct 19, 2011, 12:28:54 PM
by TURBO
Last post Jun 26, 2005, 05:55:59 PM
by 79coyotefrg
Last post Jul 02, 2008, 11:42:37 PM
by jimbo74
