1984 toyota cab, frame, motor
Started by Hyena, July 24, 2011, 08:02:46 PM
1984 Toyota Extra cab truggy. everything behind the dash is gutted. Come with a fresh 22re, tranny, NO tranny or cases.  All interior that you see in the pictures (seats, speakers, amp, sub).  rear is setup for a dual triangulated 4 link.  front is setup for a 3 link with panhard.  Come with an orbital steering valve mounted but no other steering components.  A custom 14 gallon or so stainless steel fuel cell using the stock toyota pump. A storage box and ice chest.  The motor will run when it is picked up. No key it is setup with a push button switch with separate ignition and fuel switches.  It will NOT come with the axles, master cylinder or any suspension components.  I will leave the battery and winch hooked up so it is easier to get onto a trailer but they do not come with the truck.  Truck is green stickered till June of 2012 and i have the title.
Also comes with a front range style t-case mount.
$1200 OBO. let me know if you have any other questions.  Truck is located in Chico, CA 95973.  pm here or call brad at 916-223-7641.
91 ex-cab
Holy fu**  :yikes:. My favorite toyota of all time goes for sale, and the bank account is just shy :down:
Shamb
more importantly whats on the agenda Brad?
This truck is certainly TRAIL RATED :D
Good luck with the sale.
Sparkplug
sorry to hijack, bad ass truck man, but what did you use for the tubing to route your intake into the cab, and how did ya go about it, if I may ask?
It doesn't go into the cab, it stops just short of the firewall. I am pretty sure it is just 3 inch exhaust tubing bent in a u.
Slolyfe
The end of an era. Good luck buddy. Bump
You'll never take me alive
madhunt
HIGH AND TIGHT OFFROAD
I am not sure. If you are interested I can check.
madhunt
can you  i am interested in the motor and harness and ecu, or what may be left
