Author Topic: Chevy spring swap Lift Question? NEED HELP  (Read 2888 times)
93REDCRAWLER
  • Turtle Points: 110
  • Male Posts: 563
  • Member since Nov '10
  • You see it we wheel it
« on: Jul 24, 2011, 09:21:13 AM »
So Ive read the thread on the Chevy springs but i still have a question that wasn't answered.
I'm planing to do the spring swap shortly but this is my problem.
I will be doing the swap on my 93 pickup ifs. with four inch ifs lift in the front and four inch blocks in the back. so when i do the spring swap (they say that it gives you between 2-3 inches of lift) So how do i get my other one to two inches of lift i need? can i just buy longer shackles if this is an option? or do i have to find some one to two inch lift blocks for the rear?
any help would be great
thanks in advance
R.DesJardin
  • Turtle Points: 680
  • Male Posts: 489
  • Member since Mar '08
    • RADesigns Products LLC
Re: Chevy spring swap Lift Question? NEED HELP
« Reply #1 on: Jul 24, 2011, 11:01:43 AM »
Run longer shackles, you will need some kind of new shackle setup any way. Don't do blocks!
R.DesJardin
93REDCRAWLER [OP]
  • Male Posts: 563
« Reply #2 on: Jul 24, 2011, 07:43:47 PM »
I'm  gonna do the dual shackle sett up in the rear.
ill probable use the 6 inch shackles that marlin sells. do you guys think that those will give me enough lift?
thanks again for the help
93REDCRAWLER [OP]
  • Male Posts: 563
« Reply #3 on: Jul 29, 2011, 08:23:16 PM »
anyone?
Tallchevy
  • Turtle Points: 236
  • Male Posts: 3,562
  • Member since Dec '06
« Reply #4 on: Aug 03, 2011, 09:42:17 AM »
When I did my swap I used a Chevy lowering shackle because its longer. That should give you about the amount you need.
87 4Runner redo
93REDCRAWLER [OP]
  • Male Posts: 563
« Reply #5 on: Aug 04, 2011, 06:35:13 AM »
k do i still run dual shackles with this or will i not have too?
Where did you purchase the lowering shackle?
1980yota
  • Turtle Points: -2
  • Member since Jan '11
« Reply #6 on: Aug 08, 2011, 02:26:59 PM »
I used the stock chevy shackle bolted to the stock toyota hanger then welded up to the frame. From there I used a 5.5 inch schackle down to the spring (so technically its not a dual shackle since they both dont move but I used two shackles to locate the point of rotation). Worked out great. I think I have between 3-4 inches of lift, its just a little lower than my ruf's which is how I like it to get a little weight transfer to the rear where there is none.
93REDCRAWLER [OP]
  • Male Posts: 563
« Reply #7 on: Aug 08, 2011, 05:35:05 PM »
Sweet man thanks for the info.
What did you use for the front hanger?
Last post Aug 14, 2003, 11:16:41 PM
by WHITE_TRASH
Last post Apr 17, 2006, 10:42:33 AM
by Mnmstoy
Last post Jan 31, 2007, 07:38:32 PM
by MiniSimp
Last post Mar 25, 2011, 05:16:15 PM
by DBCFR
Last post Nov 15, 2012, 09:48:09 PM
by Nimyad
