New to Toyotas - Tucson AZ
Started by Sin, June 02, 2011, 10:13:29 PM
Sin
Hi, well as the title says I'm new to Toyota's.  I bought a 91 Toyota PU, Excab, SR5, 4wd, 3.0L, 5psd, it has 35's and a 3"body lift.  The list of "needs" on this truck is huge!!!!  The body looks horrible, the front 3rd member is missing, as well as the cv's and drive shaft.  And just to name a few of the "needs" - P/S leaks at the res, radiator drain thingy is broken so I can't drain it, needs most all hoses (dry rot), belts, intake tube is duct taped to the throttle body, since it has a body lift the frt bumper was held on by the end 12mm bolts, ignition switch is hacked (looks like it had been a theft recovery at one point, but the vin matches - title, frame, door tag and dash)  :blah:
Anyways, I have my weekends planned out for awhile with this truck! So far I've installed a used hood, small repair on the core support, battery ends, battery, tie down, window hand cranks knobs and repaired the seats (cause they didn't move forwards or back and bolted down the bed! I would turn right and the bed would move left!!!  :gap:
Also if there's anyone in the Tucson area that'd like to shoot the :pokinit: sometime, I'd love to pick your brain about these trucks!  I've been reading many post on YotaTech for the past 2 weeks and decided I needed all the input I can get!
Ultimately my plans of use are to explore mines, ghost towns and have a reliable vehicle to drive from my home, explore and drive back!  Eventually I'd like the down size to 33's, remove the body lift and install an actually suspension lift, remove the ABS (since the dash light is on anyways) and just go through EVERYTHING!  :yikes:
On to the pics...!
(with the used hood installed)
(trying to figure out this mess of wires!)
yoshaleng
toe
Me
93REDCRAWLER
Muddytazz
Build it right or get off the trail
Sin
Thanks guys!
Unfortunately no work on the Toyota, unless you call power washing the undercarriage for the third time (used the two post lift at work and the big gas dewalt sprayer).  Oh and also I scotchbrited the truck today, the PO rattle canned the, this truck will be functional, and not pretty!   :gap:
Yota87Truck
Welcome!  Good platform to build on!
AzTony
prawl44
 :welcome: bro looks like a good tuck just need tlc how far have you gotten ?
Sin
Quote from: prawl44 on June 07, 2011, 08:22:20 PM
Other than a battery and some terminals, not very far!
Tomorrow I hope to get a new radiator, and start on hooking up the Taurus fan mod.  Also did a cheapo paint job tonight, I painted the truck Desert Flat Khaki!  Looks WAY better than the previous black!
prawl44
sick gotta put a pic up but long as you keep movin on it its gonna be worth it
Sin
The way the truck looked when I first bought it
Here's the new paint!  :gap:
Went over the undercarriage too
Peterbuilt84
Like the new paint, just a rattle can?
prawl44
Sin
Quote from: Peterbuilt84 on June 08, 2011, 10:07:11 PM
Yup, Rustoleum Camouflage Series - Khaki, I used 7 cans and the undercarriage was Rustoleum Satin Black almost 3 cans
Thanks guys, I'm thinking of doing a stripe down the side with maybe the same type of paint, but OD green, I've got a ps'd pic around here somewhere...
This pic is photoshoped with the graphic and cut the rear bed flare area, this will give me a good idea of what it'll look like!  :gap:
Yota87Truck
I like it but im not sold on the area above the front fender. But I am also a fan of stock SR5 look a like graphics.
Like these: http://board.marlincrawler.com/index.php?topic=44007.0
yotrunner
Bob Maldo
BadnewsBob
Howdy from another noob....Looks like a fun truck to me.....I like junk.
AE2 USN ret
No matter where ya go..... there ya are.
Hillbilly Offroad
84 xtra cab on 63" chevies and RUF 35" KM2s 22R 5 speed DTC 5.29s Locked front and rear.
Yota87Truck
874runnertoys
