Author Topic: Single u-joint Up Front  (Read 2371 times)
lownlinked85
  • Male Posts: 408
  • Member since Mar '08
  • Yeah Baby!!!
« on: May 12, 2011, 04:34:38 PM »
Hello everyone, I basically want input or opinion on running a single U-joint on my front driveline. My CV took a :pokinit: and I need to replace it on the cheap I would love to have a CV up front but they are too expensive and getting hard to fine anyways If anyone ran a similar set up which is to u-joints upfront please give me the pros and cons of the setup I am currently running dual cases so that is why I consider this setup let me know thanks guys  :beerchug:
Low locked and ready to rock
<MIKE>
  • Turtle Points: 41
  • Male Posts: 618
  • Member since Dec '09
  • Swap, Lock, and Rock it
Re: Single u-joint Up Front
« Reply #1 on: May 12, 2011, 05:07:55 PM »
I run single U-joints up front. I don't have any issues with binding either.
1987 4runner
Dual cases, 2.28-4.7
Dana 60 Rear; Danna 44 front; 5.89’s
249:1
lownlinked85 [OP]
  • Male Posts: 408
  • Yeah Baby!!!
« Reply #2 on: May 12, 2011, 05:34:11 PM »
yeah thats my biggest issue wat about vibrations? Do you feel anything?
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #3 on: May 12, 2011, 05:47:07 PM »
IFS CV clearenced will work fine. I do not know where you live but I find them all the time in California at the P-N-P for about thirty dollars. One of the best things to use is the single U-joint that comes on the IFS front d-line. For some reason Toyota made them with a lot of angle to them, more then the SA front D-shaft has.Do you have a single case or dual cases? How fast do you drive in 4 wd to worry about vibration?
lownlinked85 [OP]
  • Male Posts: 408
  • Yeah Baby!!!
« Reply #4 on: May 12, 2011, 07:37:12 PM »
I have dual cases I was trying to fine an 85 rear driveline and work that into my front as far as speed Id say 40 at the fastest because In some spots you may need to get to point a to point b relativeley quick. so will the u-joint off the front of an IFS front drive shaft work the best? That too let me know what your driveline consist of I have the brand "x" long slip driveline.
OOPS
  • Male Posts: 2,561
« Reply #5 on: May 12, 2011, 09:11:31 PM »
I got my D-shaft from Dave'z Offroad Performance. You will find it here.
http://www.davezoffroadperformance.com/store/long-travel-front-driveline.html
« Reply #6 on: May 12, 2011, 09:17:00 PM »
when my front shaft got bad wobbled out I pulled the cv apart and rebuilt it.  :dunno:
lownlinked85 [OP]
  • Male Posts: 408
  • Yeah Baby!!!
« Reply #7 on: May 12, 2011, 09:32:47 PM »
79coyotefrog where would I be able to find the parts I need to rebuild the cv the center sections is where all of the slop is they say the bearing in the middle may be out and according to local drive line shop it could be a $200+ repair let me know if you have part numbers
lownlinked85 [OP]
  • Male Posts: 408
  • Yeah Baby!!!
« Reply #8 on: May 12, 2011, 09:34:19 PM »
will the u-joint off of the rear d-line of an 85 work or do the IFS u-joints have the most clearance?
OOPS
  • Male Posts: 2,561
« Reply #9 on: May 12, 2011, 10:40:05 PM »
http://www.rockforddriveline.com/toyota.pdf
Dingman.
  • Turtle Points: 1125
  • Male Posts: 3,448
  • Member since Oct '08
« Reply #10 on: May 24, 2011, 05:17:52 PM »
I don't have a cv on either drivelines and I don't have any problems.
possume22
  • Member since Apr '09
« Reply #11 on: May 24, 2011, 06:37:45 PM »
i bought my rebuild kit from oriely auto parts
Last post Jan 17, 2006, 09:14:47 PM
by tj40ounce
Last post Mar 27, 2009, 01:41:02 AM
by AreYouSure
Last post May 29, 2009, 04:45:01 AM
by kletzenklueffer
Last post Jun 08, 2012, 11:30:19 PM
by Gixxer Jon
Last post Aug 23, 2013, 06:06:43 PM
by Moit88RNR
