I need help with my puzzle
Started by ADIDA4X4, April 11, 2011, 11:33:12 AM
ADIDA4X4
I started with a 1985 2wd auto on an 85 4wd frame. I wanted things to be right not just good enough so I got a 4wd manual wire harness to swap in and there ate a couple small differences that I have no clue what to do. Thank you in advance.
First I have this plug I can not find a mate for. It is on the pass. side and the other plug goes to the heater control. The other harness has a plug there that only has four pins and this one has five .
The other thing I'm not sure about is the deck lamp switch. I have come to the conclusion that it is for the light on the back of the cab, but on this harness there is no plug for it. IS there a way to wire one in? Obviously this is not the most important thing I need to worry about but I like things to function.
85 4wd 22rte puzzle
ADIDA4X4
85 4wd 22rte puzzle
ADIDA4X4
85 4wd 22rte puzzle
yota13
i have that in my truck and its not plugged into any thing i wouldn't worry about it
Toyota a reliable friend that never let's you down and loves to keep on truckin
crazykooter
Thats the plug that goes into the lower gauge cluster like a 1st gen has.  For some reason the 84-85 included this in their harness.  There is a 3 foot harness that plugs into that then ends up where a 1st gen cluster would be.
Basically its a dead connector for you.
That plug is for the 4Runner tilt-o-meter/altimiter gauges all 4Runners and trucks come with that plug even though the trucks didn't come with the gauges. I found that out when I put one in my truck and plugged it in.
