85 ext cab swap on std cab frame, REBUILT 3rz, narrowed 60's, 42 iroks.
Started by crawln503, April 08, 2011, 01:03:33 AM
crawln503
After Moab I wanted something different so I sold my cage, narrowed my front, bought 60's and 42's and this is where it stands now I CANT WAIT TO TEST IT OUT :shocking:
Specs of the 60's
Dodge dana 60 front narrowed to 64" (toyota spring perch width) Sky mfg. hysteer, 6 lug hubs, 5.38 gears, lockright, toyota flange, 1/2 ton chevy rotors and calipers with toyota conversion brake lines 35 spline outers with flanges
Jeep 60-2 rear axle 60" wide with 1.5 spacers. 6 lug semi-float 35 spline with Dutchman chromoly shafts. Shaved+ thick diff cover 5.38 gears with lockright. chevy 1/2 ton brakes and calipers
Tell me what you think :thumbs: :thumbdown: :talkingn:
-85 ext cab swap on std Toyota frame, 3rz, built narrowed 6 lug 60's duals/4.7 42's iroks
-94 Ford CCLB 12v. 6spd, pump cranked, guages, lifted & lots of other mods:smokin:
-89 ext cab Toyota, 3.4, 5spd on 33's
crawln503
well here's some pics with the new cage and alil update.........
and for the update 86 22ret 5spd :gap:
I picked it up for $1,800 with a rebuilt engine it has a stock turbo but that will quickly change I just bought a CT26 turbo. Now I'm looking for an adapter for it but I dont want to drill the holes out to make it fit, with my luck I'll mess it up.
crawln503
The plan was swapping motors and transmissions with the 86 and 94 crawler but I don't want to deal with the wiring, I deal with enough wiring at work and my girl friend wants to bring the dog with us wheeling but there's no room in my std cab so I found a 85 ext cab chassis and I'll swap cabs then engines. I know it's ALOT of work and with my working hours mon-sat 1pm to about 2am I wont be working on it all the time but my buddy did this swap to his std cab frame and I really liked it   :greengrin:
crawln503
crawln503
Change of plan I found a killer deal on a 3rz complete motor swap from a 97 Tacoma.
Here's some pics :gap:
swapping the bell housing.
my motor mounts
and I also bought this bracket so I can still use my trail-gear pump.
crawln503
and bye bye rebuilt 22re :usa:
I might be selling my 22re to my friend, If the sale doesn't work out I'll buy a 3rd gen Toyota that needs an engine and swap this one in it and sell it :beer:
crawln503
pumkin toy
97 4runner Limited
crawln503
Quote from: pumkin toy on April 18, 2011, 09:48:00 PM
lookin good dude, the 3rz will be sick!
Thanks I'm super stoked about this 3rz! it only has 120xxx miles on it with a new head gasket, and it has something like performance balance rods?  :dunno:
All I need to do is finish up the wiring, buy a pulley that will fit on my trail-gear pump and figure out if I'm going to run the radiator in the back of the bed or re-mount my winch to fit a 3 core radiator without putting my fan thru it :crazy:
pumkin toy
Quote from: crawln503 on April 18, 2011, 10:11:48 PM
engine sounds good, if it has "balance rods" its possible that the whole bottom end has been rebuilt and balanced.  Which means the pistons, rods, and crank are all perfectly balanced together so that the engine can turn higher RPMs wthout coming apart!
could you fit in a slim electric fan somewhere to help make room for the 3 core radiator?
97 4runner Limited
83 Crawler
Quote from: crawln503 on April 18, 2011, 09:37:45 PM
Yepp  :king:
How's the Toyota?
it's good about to start building it again. Now that I'm working again
yotaneck13
RNR FABRICATION ON THE EAST COAST!!! [email protected] (814)-516-5176 like us on facebook www.facebook.com/rnrfab
Quote from: 86bobbedtoy on May 10, 2011, 08:42:59 PM
crawln503
Quote from: pumkin toy on April 19, 2011, 06:42:09 AM
I hope I can get my 16in electric fan to fit but if not I'll have to run the radiator in the bed.
crawln503
Well here's an update. I finally got her running and dialed in and right before loading it on my trailer to go to crushers the engine just went *CLUNK* and wouldn't start after that. I finally got it running after letting it sit for a day but it has a bad rod knock :crazy:
I'm rebuilding the engine as we speak but been doing it slowly cause I just bought my girl an engagement ring and been saving up for a house but the engine was a mess, the bearings were toast even the balanced shaft bearings were bad and one was missing lol the cams were mounted on the wrong side and the head is bad too. So I'm starting this rebuild with all new parts the only thing I can reuse is the block.
crawln503
Quote from: 83 crawler on October 20, 2011, 09:03:04 AM
so wheres the crawlin 503 stickers!?:hyper: and happy for you with the engagement  :thumbs:
Thanks!! Yeah I haven't had a chance to stop by the sticker shop but I will get some stickers made soon tho
83 Crawler
tanner was telling me you guys were having a diesel drags on 205 a little while back lol, but i posted pictures of the bed on my build
crawln503
Quote from: 83 crawler on October 20, 2011, 09:09:07 AM
Lol that was tanner? What's the specs on his rig?
83 Crawler
Quote from: crawln503 on October 20, 2011, 09:17:31 AM
its a white 97 12v 5 speed and idk whats done to it he bought it like that, but it really flippin quick, i wish i could have bought his 91 std cab 5 speed cummins when he sold it :(
crawln503
Quote from: 83 crawler on October 20, 2011, 09:18:53 AM
Wow that's a clean and rare rig!!! Yeah I miss my 1st gen it sucks that the rig kid I sold it to rolled it 3 times from straightening out this corner by my house and then just gave the rig to the tow company!! :mad: :thumbdown:
83 Crawler
Quote from: crawln503 on October 20, 2011, 09:30:00 AM
ya its rare only paid like 9500 for it i think, but ya your first gen was the truck that got me into first gen cummns lol
crawln503
Here's an update :talkingn:
I will be putting my 3rz together hopefully next week and have this Toyota running at the end of Nov :crazy:
Here's some pics of the Toyota, Turbo Toyota and my new Dodge!
The Turbo rig.
crawln503
and finally the Dodge. I had a built 95 std cab 5spd cummins lifted on 35's and my buddy was hurting on cash and really liked my rig so he offered a trade that I couldn't pass up. I gave him $600 and I got to keep my lift and tires for his 2000 Dodge ext cab 6spd. Here's some pics of it with the flat bed and with the new bed now just waiting to be painted soon. :smokin:
crawln503
Quote from: 83 crawler on October 30, 2011, 11:44:58 AM
we went to browns yesterday! you missed out lol
How was it? I was in Biggs, Oregon hunting for pheasant and quail lol
It sucks not having a running rig, I've been thinking about swappng the turbo engine in the crawler till I get the 3rz running BUT that would be ALOT of work :shake:
83 Crawler
Quote from: crawln503 on October 31, 2011, 12:59:43 PM
it was wet and gay!!!
crawln503
crawln503
Quote from: 83 crawler on November 01, 2011, 08:25:37 AM
That sucks, What trails did you do?
Hit me up next time you guys go wheeling I'll add some cash for fuel :thumbs:
Oh and tomorrow I'll be getting my rebuild kit for the 3rz so I'll finally be able to put this engine back together!!!
crawln503
Here's some pics of the rebuilt 3rz in my truck today.
And here's a pic that I believe what blown up this engine :wall:
The PO used a longer bolt on the oil pan and it broke thru the front cover and into the oil pump causing the shavings to destroy my bearings.
