Author Topic: G-series Tranny  (Read 1455 times)
Gear Jammin-Dog Chasin-Yota Man
  • Turtle Points: 12
  • Male Posts: 180
  • Member since Feb '11
  • Man is saved by grace, through faith, not by works
G-series Tranny
« on: Mar 14, 2011, 12:40:09 PM »
I got this truck with a G-series tranny.
I can only find one drain plug and one fill plug for the tranny and t-case......seems odd. ???
Anyone know this tranny?
I am used to the L-series and they had plugs for BOTH t-case and tranny.
Just wanted to check if anyone else thought this was odd or if there is a plug hiding someplace strange. :confused:
1975 FJ-55 Landcruiser: pretty much stock with 31 x9.50x15 TSL's
1992 Extended Cab Pickup: 22r, weber carb, 51" RUF, F-150 rears, Aussie Front, Welded Rear, etc.
Build: http://board.marlincrawler.com/index.php?topic=78730
CLC
  • Turtle Points: 7
  • Member since Dec '05
Re: G-series Tranny
« Reply #1 on: Mar 14, 2011, 04:13:33 PM »
According to Marlin the transmission drain plug is 1 1/2" forward of the cast iron plate located in the middle of the transmission. The transfer case drain plug is located at the bottom of the t/case housing. The transmission fill plug is located on the driver side of the rear housing 3 1/2" behind the cast iron center plate. The transfer case fill plug is located on the rear fact just to the right of the 7-bolt rear seal, speedometer housing. Hope this helps.
Gear Jammin-Dog Chasin-Yota Man [OP]
  • Turtle Points: 12
  • Male Posts: 180
Re: G-series Tranny
« Reply #2 on: Mar 14, 2011, 05:56:53 PM »
Thankyou for the help.
The only plugs I see on the transfer Case are on the back of it, one on the upper right, one lower at the bottom left.
I will pull them off and see if they are the right ones.
Last post Nov 21, 2002, 10:42:46 AM
by drybone
Last post Aug 19, 2004, 08:12:05 PM
by Marlin
Last post Jun 20, 2005, 06:45:59 PM
by UNBREAKABLE
Last post Dec 21, 2009, 12:46:36 PM
by sabenson82
Last post Dec 21, 2009, 01:55:49 PM
by toyodaaddict
