chopped 2nd gen runner interior cage
Started by mayberry, February 15, 2011, 04:41:16 PM
mayberry
anyone done flat belly i wonder if i have to cut out more then i marked in primer red like do i need to go all the way to the firewall
awhotrods
Looks like a good build!!  I would say start with that area, get everything mocked up, & cut as needed.  Better to cut off just enough & have less to put back together!
ToYocRawleR
Quote from: mayberry on March 23, 2011, 06:43:50 PM
no i havn't actually could it be close?
Could be reall close considering most trucks come with wider fornt axles stock.
That 14 bolt could be around 65" , that front is 64.5"
Plus if you go to disc brakes in the rear you lose about an 1" of width.
Rigs:
05 F-250 Powerstroke
93 RunneR ...Build-up  http://board.marlincrawler.com/index.php?topic=85644.0
fortysixandtwo - I drove through Dunsmuir once I dont think anything there is "super nice"
Just kidding man. I guess there is, its your bed
mayberry
cool if thats the case i may want to get that inner from you afer all if it hasn't sold yet
IronClad
Annihilation  Fabrication
Do you need a Hammer?
IronClad
IronClad
actually i take that back you wont lose any at all since you dont have slip over drums
peacesells
Are you running a rotated tcase doubler? I just cut my 1st gen out for a flatbelly, it takes quite a bit more than that. Mostly to clear the front output.
this my man lysol, fresh out the joint
mayberry
no its just a standerd adapter  ill just have to put it up there and cut what i need to this also has no body lift so i dont get any help there but i may put one on there im not sure yet
peacesells
youll pretty much end up replacing the whole trans tunnel, I forgot to mention that im running a 1in body lift. Ill try and post a picture up of how much I had to cut
Bs85
yea i have the rotated adapter and to flat belly without any body lift i had to remove the whole tunnel plus a little more where the front drive line part of the case was hitting...
Peterbuilt84
Quote from: peacesells on March 25, 2011, 01:36:24 PM
Quote from: Bs85 on March 25, 2011, 08:02:10 PM
If you guys don't mind could you post some pics?
Sorry to hijack the thread.
toygasm
very cool rig.one of my favorites.glad to see its getting a second life.all you need iza d60 for the front. :thumbs:
peacesells
mayberry
damn! ill start with my stucks through the floor and cut what i need to im sure it will end up looking like that. thanks man.
ToYocRawleR
Hey Dan when you get a chance measure both axles wms-wms.  The curiousity is eatin at me  :gap:
Rigs:
mayberry
ff 14 bolt                              67"
narrowed 44                          65.5"
semi float 14 bolt                   66.5"
standerd width 10 bolt front     69"
86bobbedtoy
post a list of everything you have planned for it.
let me know and ill give you a hand one day.
you still bringing it down?
mayberry
alright from the top
toy 22re
dual cases 4.7 rear
flat belly
4.10s for now i have 5.38s for the rear will be on the look out for a new front set
ff 14 bolt rear dana 44 front for now until i find a good deal on a 60 or rockwells front and rear
14 bolt has a lsd of some sort in it so ill see how it does if not so great ill spool it  front i would like an ARB
want to run 40" plus iroks or pitbulls or maybe tsls if the deal is good enough
either box the rear cage in for storage or build a bed for it
probably exo it but super sleak
12,000 lb winch
half doors
onboard air with air tools so i need a bigger tank
and wheel the piss out of it
86bobbedtoy
ToYocRawleR
Quote from: mayberry on March 26, 2011, 08:23:36 PM
ff 14 bolt                              67"
narrowed 44                          65.5"
Dam only 1.5" wider than the front
Rigs:
mayberry
i think i am just going to run it  and if spark plug buys my tires tomorrow ill buy your inner  if he doesn't would you trade  it for a top shift case( i want to keep it but i need the axle more then an extra case
ToYocRawleR
Yea i might be able to do that.  As always cash is better but we'll see.  Got any other parts?
Rigs:
mayberry
not really most everything i have im using i do have a top shift case style trans thatcame out of my runner and im running a forward shift case in front so i wont need it i have a what should be complete efi setup for a 3rd gen 22re still in the truck
ToYocRawleR
Dude what year is the 3rd gen?? I need the 92+ efi :pokinit: so i can swap my 4runner.
Rigs:
