Author Topic: 22r timming  (Read 1515 times)
84_yota_4wd
  • Turtle Points: 219
  • Male Posts: 831
  • Member since Feb '06
  • mountain goat
22r timming
« on: Feb 06, 2011, 11:44:36 AM »
hello everyone
ive got the old girl running again  :driving: and im setting the timing if i remember correcty they run best at around +8deg advanced. but smog info says +5deg
either way i keep restabing the distributor to achive 8deg but with no luck ive either got a range of -2 to +5 or
+12 to +20 im guessing because the marks only go to +12
i feel like when im stabing it im only moving 1 tooth.
does anyone have any advice
Marlin Crawler
(888) 94-CRAWL / 888-942-7295
crazykooter
  • Turtle Points: -369
  • Male Posts: 1,418
  • Member since Apr '09
  • Located in Byron, CA
Re: 22r timming
« Reply #1 on: Feb 06, 2011, 11:52:14 AM »
I run my truck at 5 deg and just got it smogged and passed 3 days ago.  Also if your not removing and plugging the 2 vacuum lines then it will read 12 or more.  The factory spec for a 1st gen engine timing is 8 deg @ 950 rpm's.
I run at 5 deg since it gives me better mpg and power on the freeway.
84_yota_4wd [OP]
  • Male Posts: 831
  • mountain goat
Re: 22r timming
« Reply #2 on: Feb 06, 2011, 12:39:43 PM »
yes im pulling the lines and pluging the lines themself and leaving the dist ports open is that right?
Marlin Crawler
84_yota_4wd [OP]
  • Male Posts: 831
  • mountain goat
Re: 22r timming
« Reply #3 on: Feb 06, 2011, 12:41:53 PM »
+5 would work with me as well but ive got the adjustment clocked completly counter clockwise to achive it id rather be around the middle of the adjustment
Marlin Crawler
crazykooter
  • Male Posts: 1,418
Re: 22r timming
« Reply #4 on: Feb 06, 2011, 02:27:50 PM »
Its not gonna be centered like a RE engine would be.  It will pretty much always be rotated all the way clockwise.  If u get it to 5 then your fine and leave it there.   Try it at 5 and see how u like it.  Change it to 8-10 deg and see how it runs for u.  Every engine has its own sweet spot.
84_yota_4wd [OP]
  • Male Posts: 831
  • mountain goat
Re: 22r timming
« Reply #5 on: Feb 06, 2011, 05:06:58 PM »
Ok sounds good I think I'm gunna rebuild the carb as well it sat 4 a few years so with the new motor it sputters just a bit at idle
Marlin Crawler
crazykooter
  • Male Posts: 1,418
Re: 22r timming
« Reply #6 on: Feb 06, 2011, 06:08:48 PM »
If it has A little miss at idle and the carb had been rebuilt already then it might just be the idle mixture screw isnt adjusted right.  Or It could be vacuum lines if it sat.
84_yota_4wd [OP]
  • Male Posts: 831
  • mountain goat
Re: 22r timming
« Reply #7 on: Feb 06, 2011, 06:18:23 PM »
I'm preaty sure the vaccum lines are correct I still have my diagram on my hood I've got the idle mix at 2 1-4 out what do run urs at?
Marlin Crawler
crazykooter
  • Male Posts: 1,418
Re: 22r timming
« Reply #8 on: Feb 07, 2011, 01:09:07 AM »
The idle mixture screw isnt a set turn out.  Start your truck and let it warm up to normal operating temps.    To adjust the it you back off the idle screw until the idle rmps stop raising.  This is where you want it.  I cant tell you how many turns out it is but if I were to guess its around 8 or more.  In pretty much every carb I adjust, its pretty close to the same.  As for the vacuum lines,  I was referring to them being cracked or just plain old and hard.  Which can cause a decent leak.
If your idle mixture screw is only 2-3 turns out then that explains the rough idle.  I would start there then check cold idle setting.  If this is set incorrect it will cause a rough idle.  I set mine to 2300 rpms.  Toyota spec is 2600 I believe.
84_yota_4wd [OP]
  • Male Posts: 831
  • mountain goat
Re: 22r timming
« Reply #9 on: Feb 07, 2011, 08:29:30 AM »
Ok ill try that when I get home from work thanks I was under that impression because when I rebuilt my carb a few years ago it said that was factory stock and not to adust it.
Where is the cold idle adustment?
Marlin Crawler
84_yota_4wd [OP]
  • Male Posts: 831
  • mountain goat
Re: 22r timming
« Reply #10 on: Feb 10, 2011, 10:24:26 AM »
I tried the idle mixture screw adjustment like you told me and it worked great :beerchug: thanks for the good advice
Marlin Crawler
crazykooter
  • Male Posts: 1,418
Re: 22r timming
« Reply #11 on: Feb 11, 2011, 05:59:25 PM »
No problem......Any time.  So I take it your idle is smooth now ?
Last post Jan 04, 2008, 06:22:10 AM
by robrub00
Last post Jun 23, 2007, 02:04:46 PM
by croberts
Last post Oct 18, 2008, 02:29:16 PM
by robrub00
Last post May 10, 2009, 09:04:41 AM
by 79coyotefrg
Last post Oct 09, 2011, 10:45:38 AM
by Japjeep
