Author Topic: T case parking brake  (Read 12263 times)
theslayer85
  • Turtle Points: 83
  • Male Posts: 300
  • Member since Dec '10
« on: Jan 24, 2011, 11:56:48 AM »
Ok i did a search and didn't come up with much on this.  What are people using?  Good, bad, like, dislike?  I am planing on doing a disk brake swap into my 4runner soon which will eliminate my parking brake and looking for options.  I know they have rear disk brake kits were the caliper has a built in parking brake but they are much more expensive, and i already have toyota calipers i am planning on useing.
GNasty 82
  • Turtle Points: 994
  • Male Posts: 206
  • Member since Nov '09
  • Get Nasty!!!
Re: T case parking brake
« Reply #1 on: Jan 24, 2011, 12:03:46 PM »
Search... blah... blah.  Yeah, I know the search feature here is pretty much broken, so here's a couple of links:
http://board.marlincrawler.com/index.php?topic=76941.0
http://www.allprooffroad.com/pickupbrakeupgrades/33
82 Toyota SR5 Pickup
  Marlin Dual Ultimate
  Front 5.29 LC HP Elocker
  Rear 5.29 Grizzly Locker
  BFG 37" KM2s
  Custom rear frame and flatbed
  Propane Powered.
Build Thread:
http://board.marlincrawler.com/index.php?topic=64521.0
"The two enemies of the people are criminals and government, so let us tie the second down with the chains of the Constitution so the second will not become the legalized version of the first."-Thomas Jefferson
theslayer85 [OP]
  • Turtle Points: 83
  • Male Posts: 300
« Reply #2 on: Jan 24, 2011, 12:26:47 PM »
I guess what i am asking is who makes them and how good they are.  i found one that is much cheaper than all pro's kit and the other one is more and i dont know how it works at all, but if i go cheap am i getting cheap stuff?
http://www.sky-manufacturing.com/new/detaproduct.php?id=142
http://www.tsmmfg.com/4067.htm
SloCrawler
  • Turtle Points: -116
  • Male Posts: 1,333
  • Member since Mar '08
    • http://board.marlincrawler.com/index.php?topic=60800.msg856812#msg856812
« Reply #3 on: Jan 24, 2011, 05:01:08 PM »
How's this compared to a line lock?
GNasty 82
  • Male Posts: 206
  • Get Nasty!!!
« Reply #4 on: Jan 24, 2011, 05:22:56 PM »
It's definitely a simpler install, plus you get to use your stock ebrake handle.  No lines to run, no worries about leaking.  Also locks all 4 wheels if in 4wd.
  BFG 37" KM2s
  Propane Powered.
Build Thread:
<MIKE>
  • Turtle Points: 41
  • Male Posts: 618
  • Member since Dec '09
  • Swap, Lock, and Rock it
« Reply #5 on: Jan 24, 2011, 06:08:05 PM »
I would go with either all pro or Sky. They are both reputable companies. all pro also has a kit with a t case skid/crossmember combo.
  my 2 cents
1987 4runner
Dual cases, 2.28-4.7
Dana 60 Rear; Danna 44 front; 5.89’s
249:1
mtm
  • Male Posts: 58
« Reply #6 on: Jan 26, 2011, 03:42:59 PM »
i have allpros and can reccamend it dead easy to install
hilux 82 with mk3 2.4d engine. bobed 18 inches, full soft top, 9 inches of lift,exo cage,swing out tyre carrier, front tube winchbumper with x9, rock sliders, rear tube bumper, front truetrac and rear arb lockers, twin trans adapter with 4.7 crawler gears,20 forward and 4 reverse gears, 38 inch super swampers , rear disc brake conversion, trans disc parking brake, 5.29 r&p ,rear bench seat,hand throtle,custom storage boxes, custom made snorkel,onboard air compressor,cb twin bateries,split charge system, diff guards, low profile gearbox mo
« Reply #7 on: Jan 26, 2011, 09:30:03 PM »
not unless the transfer case is in 4wd at the time.
that said,  I have the Allpro ebrake and it kicks ASS
btw  my avatar was taken with the Allpro ebrake holding the truck on that hill.
4RunnerChevy
  • Male Posts: 1,426
  • Member since Sep '08
  • Santa Cruz Mountains
    • Santa Cruz Wheelers
« Reply #8 on: Jan 27, 2011, 05:50:21 AM »
Go All-Pro, or build your own with the all-pro disk.
theslayer85 [OP]
  • Turtle Points: 83
  • Male Posts: 300
« Reply #9 on: Jan 27, 2011, 07:32:44 AM »
Thanks everyone.  Now what about replacement parts?  I doubt you would ware the rotor or pads out enough to have to replace them very often unless you ride the e-brake, or dive with it on.
I have seen the disc e-brake but I though you had to use their fancy cross member.  I haven'e seen the one that just mount to the back of the t case. I like that much more.  I was thinking I was going to have to fabricate some sort of mount for it off of my own cross member.
yota4x4sc
  • Turtle Points: 28
  • Male Posts: 596
  • Member since Oct '10
  • Santa Cruz, CA
    • My YOTA Pics (click here)
« Reply #10 on: Jan 27, 2011, 07:43:55 AM »
the pads go out real quick if u ever ride the e brake........ the rotors seem to last though
nierema
  • Turtle Points: -2
  • Member since Mar '10
« Reply #11 on: Jan 27, 2011, 09:04:09 AM »
Maybe something is wrong with my all pro because it suckkkkkkkkks. I cant even get it to hold the truck in a parking lot.
Edit after looking at that pic i know something is not right with mine. Hmmm guess am going to go check it out.
4RunnerChevy
  • Male Posts: 1,426
« Reply #12 on: Jan 27, 2011, 05:38:11 PM »
Mine is not a good example, my linkage goes driver.
I'll re-line them, just get me your old ones.
It mounts, to your T-case.
Check it !
« Reply #13 on: Jan 27, 2011, 07:18:16 PM »
you can get the one with the skid plate but i didnt.   It bolts to your tcase with simple hand tools.
post pics of it and maybe we can help you fix whats wrong.
SFD4x4
  • Turtle Points: 4
  • Male Posts: 218
« Reply #14 on: Jan 28, 2011, 01:16:02 PM »
Can somebody measure the diameter of the rotor on the all pro?  I want to make sure it will fit in my custom transmission tunnel.
83 pickup, 4.88s, chevys in rear, RUF, Dual Transfers, flat belly, 3RZ swap, disc brake x4, rollin on 36" irocs
IF YOU SEE A 20' PAC WEST/CARSON FLAT BED TRAILER FOR SALE CHECK OUT THE STOLEN SECTION.  IT MIGHT BE MINE!!!!
« Reply #15 on: Jan 29, 2011, 09:02:16 PM »
i'll try and do that tomorrow if you remind me.
yota4x4sc
  • Turtle Points: 28
  • Male Posts: 596
  • Santa Cruz, CA
« Reply #16 on: Jan 30, 2011, 09:20:16 AM »
i would but it just started pouring outside just as i seen it..ill measure it when the rain stops
4RunnerChevy
  • Male Posts: 1,426
« Reply #17 on: Jan 30, 2011, 09:23:04 AM »
7 1/2 "
SFD4x4
  • Turtle Points: 4
  • Male Posts: 218
« Reply #18 on: Jan 30, 2011, 09:26:32 PM »
Awesome! Thanks!
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #19 on: Jan 31, 2011, 10:04:55 AM »
I have had an A-P brake for quite a while, when I first put it on it worked OK. Not great but not bad. This last year when I had my T-cases out I took the disc and chucked it into my lathe and took a few thousands off each side to remove the mill scale off the disc. It works ten times better now.
4RunnerChevy
  • Male Posts: 1,426
« Reply #20 on: Jan 31, 2011, 04:43:59 PM »
I did the same thing, it looked like they didn't even de-burr it.  I also turned the edge round, cause a monkey ran the burn table at all-pro, or their supplier.  Mine is older, and must have been done with plasma, I hope they have upgraded to Jet or Laser.
theslayer85 [OP]
  • Turtle Points: 83
  • Male Posts: 300
« Reply #21 on: Feb 01, 2011, 07:27:59 AM »
so it is sounding like all pro is the way to go.  Has anyone used sky's parking brake?
Last post Jun 18, 2004, 09:32:23 AM
by yotaboy79
Last post May 31, 2005, 04:06:08 PM
by notajeep
Last post Mar 29, 2007, 08:44:50 AM
by TurtleTappers91
Last post Jul 21, 2009, 09:09:27 PM
by ia yota
Last post Feb 06, 2012, 07:24:57 AM
by 4RunnerChevy
