"The two enemies of the people are criminals and government, so let us tie the second down with the chains of the Constitution so the second will not become the legalized version of the first."-Thomas Jefferson
How's this compared to a line lock?
It's definitely a simpler install, plus you get to use your stock ebrake handle. No lines to run, no worries about leaking. Also locks all 4 wheels if in 4wd.
the pads go out real quick if u ever ride the e brake........ the rotors seem to last though
I have seen the disc e-brake but I though you had to use their fancy cross member. I haven'e seen the one that just mount to the back of the t case. I like that much more. I was thinking I was going to have to fabricate some sort of mount for it off of my own cross member.
Maybe something is wrong with my all pro because it suckkkkkkkkks. I cant even get it to hold the truck in a parking lot.
Thanks everyone. Now what about replacement parts? I doubt you would ware the rotor or pads out enough to have to replace them very often unless you ride the e-brake, or dive with it on. I have seen the disc e-brake but I though you had to use their fancy cross member. I haven'e seen the one that just mount to the back of the t case. I like that much more. I was thinking I was going to have to fabricate some sort of mount for it off of my own cross member.
Maybe something is wrong with my all pro because it suckkkkkkkkks. I cant even get it to hold the truck in a parking lot. Edit after looking at that pic i know something is not right with mine. Hmmm guess am going to go check it out.
I have had an A-P brake for quite a while, when I first put it on it worked OK. Not great but not bad. This last year when I had my T-cases out I took the disc and chucked it into my lathe and took a few thousands off each side to remove the mill scale off the disc. It works ten times better now.
Started by Bazzi Engine
Started by notajeep General 4WD Discussion
Started by blyota91 Toyota Pickup/4Runner Tech 1979-95
Started by ia yota Parts Wanted
Started by ajordan1975 Parts Wanted
