sas swap on my 89 yota pickup
Started by toyocrawlr, January 09, 2011, 07:18:13 PM
toyocrawlr
Quick question I'm going to do a solid axle swap on my yota what kit would u guys think I should do I called. Martin crawler and they said that they don't carry the sas kit anymore but that I could get the same kit from all pro off-road. I also saw one from trail-gear and sky-manufactures which one would u guys recommend I use I don't want to use one that will brake or is cheap I heard that all-pro and marlin crawler was American mad and a good sas kit but has anyone else used any other kit
bigarms23
skys if your planning on running full width axles if your not and going to run a yota front axle use allpros kit its a great kit and you won't be disappointment
87hillbillyoter
first, use periods. second, listen to bigarms.
1987 SAS'ed toyota 4x4 pickup 22re swap
build up- http://board.marlincrawler.com/index.php?topic=75111.0
Toymin8r
Mine is 100% All Pro on my 89 and I have been completely happy with it for 10 years
91 ex-cab
I had trail-gear on my old truck and it wasn't to bad of a kit but the springs are crap. mine had toyota rear mains swapped in but they still weren't that great. Not sure about the all pro kit.
toyocrawlr
With sky's kits could I use Dana 44's
yoshaleng
Go with all-pro's kit...as far as trail-gears kit, everything is pretty good but their springs are  :toilet:.
I had to warranty all four leaf springs after 6 trips.
Wrong section for this you may get more help in the tech section.  :welcome:
874runnertoys
toyocrawlr
What would be a good front axle to put in my 89? And I wanted to upgrade the rear axle also
toe
Me
pumkin toy
Quote from: toyocrawlr on January 11, 2011, 06:09:49 PM
depends on if you want fullwidth axles, or if you want to match the width of your rear axle.  most of the time we dont upgrade our rear axles cuz they are damn near bulletproof from the factory
97 4runner Limited
Yota Rolla
Quote from: bigarms23 on January 09, 2011, 07:43:19 PM
X2 but i would go with the SKY'S kit for yota axles also
82 locked,geared,cased,caged daily
yoshaleng
Quote"depends on if you want fullwidth axles, or if you want to match the width of your rear axle.  most of the time we dont upgrade our rear axles cuz they are damn near bulletproof from the factory"
X2
I'm running 85 toyota front axle w/ 30 spline chromos, hasn't failed me yet.....knock on wood
yotaneck13
:welcome: from pa go marlin sas for sure!!!!!!!!
toyocrawlr
I wanted to get Dana 44s and get them made to fit my Toyota there's a shop that can shorten them for me. How would that work out
pumkin toy
that would work, but may i ask why?  why spend the time and money to narrow dana 44s to toyota width when you can just run toyota axles?   yota axles are easier to use because the aftermarket choices to make them work with your toyota truck and are alot more available.  i say stick with the yota axles
97 4runner Limited
Nimyad
X2 on yota axles, way easiet to work on too.
Trail-gears kit seems the be the most complete and definitely the one o would choose, but i'd sell the springs and just run a ruf pack
toyocrawlr
Are the yota axles as strong as the d44's ?  Or what do u guys think. Can u guys give me some ideas on how to make my yota axle stronger
91 ex-cab
not postive, but I have heard they are both about equally strong. Get a set of longfields for your front, the rear will be fine stock.
Nimyad
they're comparable to the d44. like 91 ex-cab said get some chromo for the front. stock birfs are weaker then a d44. but the rear axles are about the same strength wise.
only way i'd go through the effort to put d44's in my truck would be it i did the jana 54 kit...
91 ex-cab
Quote from: 4.7Crawler on January 26, 2011, 11:00:00 AM
Hello
Come on man seriously! Great you got your 12 posts but 9 of them are hello. If you just want to gain posts at least say something more than hello ::)  :spankbutt: :shake:
yoshaleng
As mentioned above, the toyota axle is alot easier to come by, no extra cash to get it shortened, and almost equal to strength. With that money thrown away to shorten the D44, you can buy Longfeild w/ lifetime warranty and it would be plenty strong.
pumkin toy
Quote from: toyocrawlr on January 25, 2011, 08:05:34 PM
put longfield chromoly birfields in the front and your toyota axles will be alot stronger than dana 44s.
97 4runner Limited
kbyers
Toy axles are plenty strong if built right.  What are you planning to do with the truck? Engine? Tires? Gears? Where do you drive? Trails? Mud? Sand?
toyocrawlr
I'm not sure on the engine Im looking for a Toyota diesel but if I can't find one I wanted to go with the Chevy vortec. With 35 or 37 inch big mud's with 4.88 or what do u think about the small block v8 or the Ford 302. I'm going to use it for trail riding and to commute I don't really have the money for a second truck. What do. You guys think
Nimyad
as long as you're not running dual cases with a v8 they should live just fine with cromo front.
Toy-Cra-Ze
