There is a ring inside the hub with ears on it, if the ears are bent that is your problem. The torn boot should not affect the locking mechanism.
Ok i took it apart and from the diagrams that rocksurf gave me, it seems i'm missing the tensioner spring for the "follower paw" and the seal was torn in two. Found mud water and grease all mixed in probably prevented the clutch from moving. Would that missing tension spring be the reason for why its not unlocking?
Junkyard will have one. You could get one off a Isuzu, sammi, yota ifs or solid, and maybe a older mitzu truck or dodge anything with a aisin hub will have that same detent spring and ball.
ah, duh sorry was drunk posting last night. But still off any of them trucks the tension spring will work.
