Author Topic: IFS hub not unlocking  (Read 2617 times)
Tofudude
  • Turtle Points: -31
  • Member since Jun '10
« on: Dec 13, 2010, 02:02:35 AM »
After a day of wheeling my cv boot on my 86 pickup ripped open. Would the torn cv boot be the reason why the hub won't unlock? i can switch it to "free" and "locked" but the half shaft still continues to spin with the tire no matter what.
fade
  • Turtle Points: -9
  • Male Posts: 1,018
  • Member since Oct '09
Re: IFS hub not unlocking
« Reply #1 on: Dec 13, 2010, 02:17:30 AM »
you might have some how stripped the gear in it but that would be really hard. Maybe you just put enough pressure on it to cause it to bind up. Try taking it off and see what you see in there might just need to be taken off and re seated.
86 mini truck 18" rays
09 highlander
70 suburban
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #2 on: Dec 13, 2010, 03:34:19 AM »
There is a ring inside the hub with ears on it, if the ears are bent that is your problem. The torn boot should not affect the locking mechanism.
4RunnerChevy
  • Male Posts: 1,426
  • Member since Sep '08
  • Santa Cruz Mountains
    • Santa Cruz Wheelers
« Reply #3 on: Dec 13, 2010, 05:45:47 AM »
The hub gear probably came off the spring, probably from bent ears.  I just put one back together Saturday.
x2
Nimyad
  • Turtle Points: -1
  • Male Posts: 1,138
  • Member since Sep '10
    • Buy me a cigar
« Reply #4 on: Dec 13, 2010, 07:56:47 PM »
maybe the spring inside slipped. mine did that after i rebuilt my knuckle on a SA. just unbolt in and twist the spring in if thats the case
yota4x4sc
  • Turtle Points: 28
  • Male Posts: 596
  • Member since Oct '10
  • Santa Cruz, CA
    • My YOTA Pics (click here)
« Reply #5 on: Dec 13, 2010, 08:13:09 PM »
use plyers and see if it will turn somewhat easy..maybe mud in it...if not take it apart
Tofudude [OP]
« Reply #6 on: Dec 14, 2010, 01:55:09 PM »
I'm probably going to take it off and check, is there anything i should be worried about flying in to my eye when i pull it off?
Would water cause damage to it. because it was working fine till a week after a trip through some water crossings.
If it is broken, is there anyone or place that could rebuild it for cheap?
Its an IFS one so i'm not sure if there is anything diffrent about the SA version.
« Last Edit: Dec 14, 2010, 02:03:13 PM by Tofudude »
Sparkplug
  • Turtle Points: -130
  • Male Posts: 2,046
  • Member since Jan '08
  • Doin it Standing Up
« Reply #7 on: Dec 14, 2010, 01:59:32 PM »
not much to break in em, esp on a stock rig. Usually they justy get gummed up, or the spring kicks sideways and they get stuck, kinda weird at first how they go together, but not too hard, really easy after you done it a couple times.
Tofudude [OP]
« Reply #8 on: Dec 14, 2010, 11:39:17 PM »
Alright, when my schooling ends this week i'll take it appart and post some picks...maybe yall can point out anything wrong with it or something. Are there any rebuild kits, might as well get one since i'm taking it apart?
  • Momentum Man
  • Lego Enforcement
« Reply #9 on: Dec 15, 2010, 04:40:28 AM »
Here is an exploded view of an Aisin Hub (Isuzu) notice that there is a small spring and ball, be careful not to loose them sucks crawling around trying to find them.
http://www.yankeetoys.org/Documents/AisinHubs.pdf
Tofudude [OP]
« Reply #10 on: Dec 17, 2010, 04:48:26 PM »
Ok i took it apart and from the diagrams that rocksurf gave me, it seems i'm missing the tensioner spring for the "follower paw" and the seal was torn in two.
Found mud water and grease all mixed in probably prevented the clutch from moving. Would that missing tension spring be the reason for why its not unlocking?
4RunnerChevy
  • Male Posts: 1,426
« Reply #11 on: Dec 17, 2010, 05:07:20 PM »
Where did it go ?
Tofudude [OP]
« Reply #12 on: Dec 17, 2010, 06:54:25 PM »
M.I.A. i did a part check after i to the cap off...and it wasn't there.
Does any one know where to get one...cause my toyota dealer only sells that spring as part of the unit
fade
  • Turtle Points: -9
  • Male Posts: 1,018
« Reply #13 on: Dec 18, 2010, 01:28:38 AM »
Junkyard will have one. You could get one off a Isuzu, sammi, yota ifs or solid, and maybe a older mitzu truck or dodge anything with a aisin hub will have that same detent spring and ball.
09 highlander
70 suburban
  • 96ZJ v8
  • Turtle Points: -415
  • Male Posts: 4,823
    • Buy me a drink
« Reply #14 on: Dec 18, 2010, 03:25:40 AM »
tension spring behind the follower paw.. not the spring in the dial itself.
fade
  • Turtle Points: -9
  • Male Posts: 1,018
« Reply #15 on: Dec 18, 2010, 10:49:38 AM »
ah, duh sorry was drunk posting last night. But still off any of them trucks the tension spring will work.
09 highlander
70 suburban
yota4x4sc
  • Turtle Points: 28
  • Male Posts: 596
  • Santa Cruz, CA
« Reply #16 on: Dec 18, 2010, 03:39:10 PM »
:biggthumpup: thats how u gotta do it
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #17 on: Dec 18, 2010, 05:01:03 PM »
Just was clarifying lol
