those brackets also use nuts to space the bracket out from the axle backing plate flange. I still feel this is a bad idea.
can u explain why you feel a nut as a spacer is a bad idea? Just curious.
well, look at the stock front brakes. they are held on by a 14mm bolt(17mm head) into a caliper mount almost 3/4 inch thick. Toyota did it that way because under high traction, with big tires, a loaded rig, and panic stomping of the brake pedal that little 10mm bolt with the nut spacing it out away from the mount will shear off like a donut at a cop convention.
here is a place i picked up the brackets i'm using http://www.ruffstuffspecialties.com/catalog/index.php?cPath=9&sort=2a&page=2 they got a few different ones to choose from
got in to toyota crawlers in 2003been making parts for the guys around here from then and still doing it !and i have never sold and parts on ebay for crawlersi'm the little guy that makes parts and buys partscould not tell you how many marlin doubler boxes i have put togetherthere is a lot of room out there and i do not feel i should talk down on a guy trying to sellhis stuff for pennys on the dollar. thats all i have been hearing (his stuff is double the cost of mine)OK !!!! sell yours for what you what to !i will not get into a price war with anyone !i have a ton of R&D in my stuff and they are not a cooky cutter partlets see how long it takes for this post to get deleted !!!I'M NOT SELLING ANYTHING WITH THIS POST !!!!!!!!!
i run into a problem running solid rotors in back if you get any play in your bearing or just wheel hard it will ruin you caliper and pads fast where they are solid mounted so i used the same brackets and used chevy rotors and calipers from a s10 and havent touched them in two years
if worried about bolts sheering use grade 8 bolt fear gone
nope it works in front you can adjust the wheel bearing load so there isnt any play like i said i had problems with that setup in the rear when wheeling hard with 42s i dont think they would be any trouble with them on a street trail truck
oops are you running plastic or metal brake lines
Started by chris672 Parts For Sale
Started by robinhood4x4 Engine
Started by 83ROCKR Parts Wanted
Started by MiniSimp Project Research and Build-Ups
Started by kiyul4130 Parts For Sale
