Rear D60 toyota hybrid
Started by robinhood4x4, March 17, 2005, 11:10:22 AM
robinhood4x4
My friend just picked up an 84 toyota truck with a D44 in the front and a D60/Toyota hybrid in the rear.  I've never heard of such a hybrid, is this common?
As far as I know, it has a D60 axle housing with a toyota axle from a 90ish toyota truck complete with toyota drums.  It was re-splined to fit the D60 gears (I think).
Are toyota axles that strong...enough to compete with the D60?
Quote from: cruzilaWell, if the ideal of excluding the lesser equipped (stock or otherwise) is accepted... there is no fundamental difference between that and a Sierra CLub ideal of exclusion. If we cannot embrace the 4wheel users as a whole. We are not fighting for access. I cannot be that shortsighted
kyle_22r
toyota axle shafts are the same size and spline count as a typical 60 rear...i really think it would be a waste of time to build such a hybrid, as all you get is reduced ground clearance.  why not build a 60 rear with 35 spline shafts?
robinhood4x4
Wow, I'm impressed that the toyota axle is as big as a d60.  So the advantage would be stronger gears?
Flip-Flop
robinhood4x4
Thanks, that's probably where it was done too.  I'll have to see what the build sheet says.
So it has better brakes than a normal D60 and stronger gears than a toy axle.
Foothill Offroad has been making those axles for some time now.  I haven't seen any on a toyota though, maybe thats a bad sign.
wrenchtech
I looked at the Foothill D60 hybrid and i noticed that it seems to have the Toyota semi-floating configuration.  That seems kind of disappointing. Or am I missing something? -- Matt
1999 4runner SR5, 3.4, auto, Horizon Blue
wrenchtech
It would be nice to have a rear axle that combines the full floating elements of the Front Range Off Road Fabrication full floater conversion kit ($789.00) -- Matt
