Author Topic: 5.29 , 5.71 or 4.10 w/duals  (Read 2734 times)
scarecrow
  • Male Posts: 33
  • Member since Oct '10
« on: Oct 25, 2010, 09:14:44 AM »
hey all toyota newbie here i just got a 85 toyota pickup w/ 4cyl 5 speed i plan on running 38s or 39s on the toyota axles i know i will need to build the axles up i am not worried about that.  i am building this toy to do alittle bit of everything. trail , crawl (nothing hardcore) , mudholes and maybe some local tuff truck....the rear will be welded and i might install a locker in the front what would yas do 5.29s , 5.71s or 4.10s w/ duals?
« Last Edit: Oct 25, 2010, 09:25:01 AM by scarecrow »
If you can`t drive over it or thru it....JUMP IT!!
yota4x4sc
  • Turtle Points: 28
  • Male Posts: 596
  • Santa Cruz, CA
    • My YOTA Pics (click here)
Re: 5.29 , 5.71 or 4.10 w/duals
« Reply #1 on: Oct 25, 2010, 09:58:07 AM »
i would either 529s or 488s cuz there stronger..i had 529s when i had yota axles..i liked them with 36 inch tires
:usa: 92 xcab, full width, 39.5 boggers, beadlocks, 60 f arb 5.86s , 60 r spool , duals, 4.7 rear... 3.sl0, bobed , all pro 6 inch leafs f and r :usa:
AaronB
  • Turtle Points: 287
  • Male Posts: 2,452
  • Member since Nov '05
  • Wish I Was Crawling
« Reply #2 on: Oct 25, 2010, 09:59:37 AM »
5.29's
HDcruiser
  • Turtle Points: 10
  • Male Posts: 580
  • Member since Dec '06
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
  • Member since Sep '04
« Reply #4 on: Oct 25, 2010, 10:49:43 AM »
Not many people here run 5.71's, or ever had any luck with them at all.  Generally, if your looking at 5.71's, then you really need to be looking at 1 ton's.
Majority of us are running 5.29's, and duals, with almost no issues.  There are few running 4.10's and duals, but it's harder on the drivetrain.  The lower gears makes it easier on the drivetrain, especially with a 4 cyl.
46&2
  • Hillbilly
  • Turtle Points: 8
  • Male Posts: 4,834
  • Member since Dec '05
  • California livin'
« Reply #5 on: Oct 25, 2010, 11:24:47 AM »
5.29  :thumbs:
mudmaster
  • Turtle Points: 3715
  • Male Posts: 2,854
  • Member since Feb '05
Time to go wheelin!
scarecrow [OP]
  • Male Posts: 33
« Reply #7 on: Oct 25, 2010, 11:42:15 AM »
thanks for the replys all...5.29s it is. would ya`s still do duals? or will the duals not allow me to spin the tires fast enuff in the mud?
P-DiseToy24
  • Turtle Points: -230
  • Male Posts: 868
  • Member since Aug '09
  • DDNB!
« Reply #8 on: Oct 25, 2010, 02:15:32 PM »
Duals will allow you the same wheel speed you have now.  That's the nice thing about duals is you get that low low but you also have the High high for mud/freeway.
I suggest duals to anyone even if your only running 35's or 36's it just gives you such an advantage if you have the choice of such a low crawl ratio.
yota4x4sc
  • Turtle Points: 28
  • Male Posts: 596
  • Santa Cruz, CA
« Reply #9 on: Oct 25, 2010, 02:17:54 PM »
ya like p-dise said... duels are almost a must..i love them..u will never have to slip clutch again with duels
scarecrow [OP]
  • Male Posts: 33
« Reply #10 on: Oct 25, 2010, 03:03:20 PM »
nice....5.29s and duals it is....my truck is setup for duals but only has a single in it now. i have a hole cut in the floor and mounts welded to the frame. i guess the prievous owner had intentions of duals just never finished it. so what all i need to do is get another toyota tcase rob the gear box off of it order an adapter and bolt it to the front of my tcase now.???
« Last Edit: Oct 25, 2010, 03:42:55 PM by scarecrow »
joshcraig09
  • Turtle Points: 4
  • Male Posts: 128
« Reply #11 on: Oct 25, 2010, 07:05:25 PM »
yeah sounds like u got it now... good luck
<MIKE>
  • Turtle Points: 41
  • Male Posts: 618
  • Member since Dec '09
  • Swap, Lock, and Rock it
« Reply #12 on: Oct 25, 2010, 07:10:18 PM »
ya then you will have to re do your drivelines.
1987 4runner
Dual cases, 2.28-4.7
Dana 60 Rear; Danna 44 front; 5.89’s
249:1
scarecrow [OP]
  • Male Posts: 33
« Reply #13 on: Oct 26, 2010, 05:13:34 AM »
i am not worried about that my front shaft has to be done anyway and the rear has a trashed carrier bearing and i would like to get rid of that all together and make 1 shaft from rear to tcase.
scarecrow [OP]
  • Male Posts: 33
« Reply #14 on: Oct 26, 2010, 05:22:35 AM »
thanks for yer help so far everyone....is there a specific year range tcase to look for to do the duals. i was reading so post that i found while searching. man i didn't realize toy has so many different cases top shift , front shift , chain , gear , rotate.....man that made my already confused mine worse... lol
yota4x4sc
  • Turtle Points: 28
  • Male Posts: 596
  • Santa Cruz, CA
« Reply #15 on: Oct 26, 2010, 08:32:32 AM »
get a top shift gear drivin case..like 79 to 85
Last post May 02, 2006, 11:27:01 AM
by 79coyotefrg
Duals or 4.7
Last post Aug 24, 2008, 06:41:19 PM
by Duffil
Last post Apr 02, 2009, 01:55:24 PM
by emsvitil
Last post Aug 27, 2009, 10:33:45 PM
by Talon84x4
Last post Nov 02, 2010, 10:46:03 PM
by Jagdverband44
