Which Engine and Why? (going 4.3L CPI, Posts pics please?)
Started by THK Matt, October 03, 2010, 05:30:28 PM
1.9L VW TDI
4 (26.7%)
2.7L Toy I4
3 (20%)
3.4L Toy V6
2 (13.3%)
4.3L GM V6
2 (13.3%)
5.7L GM V8
2 (13.3%)
Other?
2 (13.3%)
Total Members Voted: 15
Quote from: COToy91 on October 03, 2010, 11:05:19 PM
Crossmember is in the stock location, but i have a budbuilt. You will need a shifter for the trans, I used a B&M, some guys like lokar better. Also a transcooler. I am sure there is more, its always the small things
Small things suck lol.
Just a simple shifter will do, yes?
COToy91
I used a B&M sport shifter, works great and it was the cheapest they made for the trans
#32
Quote from: COToy91 on October 04, 2010, 10:51:02 AM
best place to buy it?
EDIT:
is this the one?
http://www.summitracing.com/parts/BMM-80776/
OH and how about a Radiator & Fan, ryan?!
COToy91
Quote from: THK on October 04, 2010, 11:49:12 AM
That is the shifter. I used a universal radiator from speedway motors 22" x 19" and a mechanical fan, but I am probably going to swap that out for an electric
zippo
I know you've prolly made up your mind. But I say stay Toyota. makes thing easier and cooler. Though all engine swaps are cool.
If you see it, its for sale.
Quote from: COToy91 on October 04, 2010, 02:46:34 PM
Awesome!!! whats the outlet configuration? top D.S. and bottom is P.S.?
THK, what state do you live in?
Quote from: THK on October 03, 2010, 05:59:19 PM
Idaho
Depending on what smog requirements you are subject to, my first choice would be a Turbo diesel 4- or 5-cylinder (however I have NO experience here), or my 2nd choice would be the 3RZ.
I would need to know more about the use of the vehicle. What type of wheeling? How much daily driving? Longest road trip you'd expect to take? How heavy is your truck with the 22R? Will you ever go over 37" size tires? Do you live in a valley, foothills, mountains? Will you do any towing?
Quote from: zippo on October 04, 2010, 03:34:56 PM
I say stay Toyota.
X50
Quote from: BigMike on October 04, 2010, 04:01:16 PM
X50
I live in a valley of mountain ranges, quite a few passes, hills, etc. It will be 80% DD. I like Rockcrawling, fireroading, snow wheeling. I eventually plan to go to a 40" tire sometime... towing would likely happen yes. and I dont know the weight of the xcablong beds.
superyota
the only engine i would consider doing a swap, other than a stock replacement, would be a LS based(4.8,5.3,5.7,6.0) GM with a 4L80. only reason being is i worked in a shop and spent a lot of time on these swaps.  very reliable, easy wiring, easy smog, and not to mention lots of power, and for cheap :eyebrow:
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
the LS 5.3's are wicked lol
those are in the Tahoe's arent they?
superyota
Quote from: THK on October 04, 2010, 04:26:35 PM
tahoe's, trucks, suburbans... great motor.
ABD Motorsports
#4475
KK6QDW
Quote from: superyota on October 04, 2010, 04:29:15 PM
Thought so, yes those are some quick engines, my cousin has it in her 01 Tahoe.
yjay
LS with toy axles for towing?
22re Daily Driver
http://board.marlincrawler.com/index.php?topic=56568.0
91 4Runner-R151f, MC07,23 spline duals, Marlin 1200lb clutch, 85 Front axle, Leaf swap rear, Yukon 5.29's, BFG KM2 35's, Detroit, OBA, 280k
superyota
ABD Motorsports
#4475
KK6QDW
noflyzone
3rz and re gear to 4.88's for all the same reasons that have already been said. Especially Toyota reliability
COToy91
Toyota motors and swaps are not very cheap
Quote from: superyota on October 04, 2010, 04:20:57 PM
Quote from: yjay on October 04, 2010, 04:54:57 PM
Quote from: superyota on October 04, 2010, 05:01:01 PM
1 tons would be a good idea :yesnod:
I'll pick on this because it is so much fun to do:
While your doing the V8 conversion THK, make sure to add a 1,200 pound Grand Piano for a sound system so you can actually hear your Mozart while going uphill at 80 MPH, then be sure to add a 1,500 pound King Size Water Bed so you can rest and recover from the nose bleed once you get to the top of the mountain, make sure to swap out the Toyota frame with one from a 24,000 pound Class A 3-cylinder Shay Locomotive to make sure your truck doesn't buckle under the weight. Also, you'll need to have a 33-foot diameter wind tunnel fan to keep the engine compartment cool and you will need to mount at least a couple fuel tanks from a Antonov An-225 Mriya airplane somewhere to your rig so you can make it in between gas stations to refill along your way.
:rofl2:  :popcorn:
yjay
I don't get it. He says he wants to run 40's and tow. Wouldn't Toy stuff be a bit undersized?
We do live in the mountains.
22re Daily Driver
yjay
At least the axles? A 3.4 would be good though.
22re Daily Driver
Quote from: yjay on October 04, 2010, 06:45:49 PM
I dont have have money to do an engine, gears, axles, etc. and doing a toy engine swap... yeah too much money for the output ill get. I do not want a 4cyl. Im running 4.10s and i want to confidently push 37s+ without a struggle that a 4cyl will have. Ive had enough of those. im not saying im purpose building it on 40s to tow. i tow a utility trailer from time to time and do other heavy loads as well and 4cyls just arent up to the job for me. So going with a 4.3L and 700r4 with a toy tcase will be perfect. toy swaps are just too expensive.
when i do step up to a 40, i will also do longfield 30spl shafts and FF the rear out. "stage 2" I think the 4.3L and what COtoy91 has said is perfect for me.
bigarms23
i also used a speedway motors radiator and a 16inch flexalite electric fan
Quote from: THK on October 04, 2010, 08:41:35 PM
For a daily driver with 40s you'll definitely want to run either a V6 petrol or turbo 4- or 5-cylinder Diesel (equal torque but better fuel mileage).
Mike
zippo
By the time you run a 4.3L, 40's, I would bump to a D60 for reliability. That way you can keep your foot in it going up the trail and not worry about making it home. Could even throw a supercharger on it. With that combo you are really pushing the Yota drive train.
Even a 4-banger on 40's is pushing it.
noflyzone
It would be cheaper just to buy a Chevy Truck.
COToy91
Quote from: noflyzone on October 05, 2010, 03:00:43 AM
word, CUCV or something. It makes me cringe if I think about how much I probably have into my rig. Oh well i like it
superyota
Quote from: BigMike on October 04, 2010, 06:30:05 PM
:rofl2:  :popcorn:
just my  :twocents: , but i have a 4.8L in a 5200lb truck, and i'm averaging 18mpg on the freeway, not to mention is c-channel frame, vs. the toyota boxed frame.  ls motors are really smooth, if left stock.  i don't see why you would get any more vibes than a stock drivetrain.  aluminum radiator with an electric fan keeps them plenty cool.   :gap:
ABD Motorsports
#4475
KK6QDW
