New to the Marlin Board
Started by TractorDriver, September 21, 2010, 04:55:00 PM
TractorDriver
   Hey my name is Adam I live in Tuscaloosa Al. I have had several Toyota based rigs and a one ton yota thing. I currently am driving a 2 seater comp buggy called The Rock Tractor that is built with one thing in mind to be the toughest little buggy on the trails it is built with as many Marlin Crawler parts as possible!
Here is a run down of my tractor:
Engine: 22r on Propane (Got Propane)
Trans W56b (for now)
Tcase: Ultimate comp duals fully loaded!
Front axle: 84 mini, HP 4.10 welded, longfield hub to hub 30spline, arp studs, 5th studs, MC 25mm pin kit with MC arms,diff cover,seals,and bearings
Rear axle: 96 Tacoma 8.4 4.10 welded
Suspension: Single triangulated 4 link front and rear, aluminum uppers 3/4 heims, solid steel lowers 3/4 heims, 106" WB, and 16" Radflo 2.0 airshocks front/rear
Chassis: 2 seat ultra light
Weight: 2,700lbs ready to ride
Height: 73"
Belly pan: 22"
Tires/Wheels: 39.5x13.5x17 Iroc's MRW 17x9 black steel
Recovery: Warn 8k Synthetic rope
Rock Tractor Racing
Gasss Ittt!!!!
Climbintathatop!
Special Thanks to: MarlinCrawler, Inc.
unclejpl4x4
toe
Me
axled89
i love oregon wheelin.
IXLR8
TractorDriver
Rock Tractor Racing
Gasss Ittt!!!!
Climbintathatop!
