I've been reading that(thanks) and I think the problem (due to other symptoms such as 1-2 shift bogs down) is that the Vacuum modulator assembly needs to be replaced as it looks like the original part.(def clean out the screen first, though.)If this fails, it's off to the exhaust shop to unhook the cat, o2 sensor(have plate for that hole), and exhaust and run some seafoam or similar to blow out the carbon and gunk.(don't want that crud in the cat, sensor, or muffler, naturally). Because the only thing that will fix it at that point is getting rid of the crud in the cylinders. With 200K on the engine(runs perfectly fine as 75% of that is highway commuting) and no other symptoms, if it's not the EGR, then it's just full of gunk that I need to blow out.Though, I hear that Toyota sells a similar product (engine pre-tune IIRC) that supposedly does the same thing for cleaning the throttle-body. Any experience with either of these on old engines?EDIT - I found some before and after pics. The stuff seems to work to get out maybe 30-40% of carbon at most on a dirty engine(far from a miracle cure), but def needs to be run with the exhaust parts you want to save OFF of the thing. Apparently using it and clogging your cat is a fairly common "oops". The stuff itself won't cause any damage, but the junk it spews out certainly will cause all sorts of ills.
got a pic/diagram? Somehow my old brain isn't figuring out what to do from the description. I'd love a $5 fix(don't think it'll make much difference in how it runs, since the EGR is on most of the time driving around anyways - just isn't apparently reacting quick enough)
Well, I backed off the timing to stock(runs like crap now) and dumped a whole bottle of octane boost in it. And somehow managed to pass. 1050 or so at 15mph and 350 or so at 25mph. Basically EGR not engaging at all, but I managed to get a bit lucky.(the fuel additive did drop 300-400 off the NO reading, so without it I'd have been out of luck.But the other issue is of course that HCs are right at the limit. I guess it's to be expected given that this is La-La Land and the idiots in charge here make it impossible for any engine with over 150K miles to pass.(anyplace else the numbers would be more than acceptable - the engine runs very well normally.(have to set the timing back to 10 degrees tomorrow)Probably the last time I ever smog it, though.
Started by TacoRunner General 4WD Discussion
Started by wildchild1066 General 4WD Discussion
Started by Travis H Toyota Pickup/4Runner Tech 1979-95
Started by dntsdad Newbie Questions
Started by eskimo19 General 4WD Discussion
