Project Sparkplug (88 4Runner)
Started by Sparkplug, August 26, 2010, 06:28:53 PM
Sparkplug
Got my steering all buttoned up, looks good to me, no issues with clearance at all. The box is all the way agianst body mount, and rotate just a hair up. Still gotta finish grinding frame, and paint everything, also need 2 more u bolts, and shocks. But she steers and drives now, wooot!!!!!
Sparkplug
Poser shot, dont have tres yet, mine r shot, so cant go test it on rocks. But everything clears, at max stuff, by 1/8 inch. Im happy, Movin on to rear suspension tomorrow, decided on tried and true 63s. Think it will work perfect. Not me in pics, my bud. Opinions wanted.
rockin86runner
danm 3 tires high :yikes: for flex ...lol its looking good man keep up the good work cant wait to see it done
85 toy runner tons 4link front and rear ORIs 42 pitbulls
86 runner some other things  pained orange STOLEN REWARD IF FOUND
70 cj-5 renegade1 buick 231 v-6 t-18 dana20 dana 30,44 32in BFG at
:usa: USN SEABEE EO2 SCW .....We Build.We Fight.We Defend....Hoo-Rah  GOD BLESS OUR TROOPS :usa:
<MIKE>
looks good man. i really want a 2 gen runner to swap. what size tire do you plan on running?
1987 4runner
Dual cases, 2.28-4.7
Dana 60 Rear; Danna 44 front; 5.89's
249:1
Sparkplug
I plan on 36 or 37 to start with, then who knows, cud go to 4DS. With a 37 I thinkin my tire will stick out past my front end.
4x4yota
4runner is turnig out sick can wait to see what the rear is gonna look like so I can start planning my truck Im liking to low lift RUFs
Current:
Sold:
SloCrawler
Nice build. Your not worried about your pitman arm hanging up on your spring when shoved. Only reason I ask is it look like mine. And mine hits.
Sparkplug
yes, my pitman arm does slightly hit on driver side,w hen it fully stuffed. That why i said I need a 3/4 less drop, or possibly flat one. But it only hits after spring has gone negative, so I will only need to change it to flatter one, if I decide no to run bump stops, otherwise, with bump stops, no it wud not hit.
Sparkplug
Got it almost all the way done. Gotta grind everything off frame, and paint, put on shock hoops, and shocks, and get a 3.4 drop pitman from sky. Otherwise, its done, and drives great down the road, even without shocks. Can let go of wheel at 60 mph, and it stays straight. For reference, it has a unmodded stock rear pack for front suspension, and chevy leaf springs out back with 2 leafs plus overload. I may have to add a leaf to the back to level it, but I hope my front is gonna sag to flat, in which case it will be even. Frame height is 19.5 inches to ground at frame behind shackle mount, on 31 inch tires, that actually measure 31. Opinions or kudos wanted, thanks again.
Sparkplug
Tomorrow, Im pullin trans and case, to install duals, and plating front of frame, and front hanger. Tires coming soon
Sparkplug
Made a custom pitman arm from a 2wd drop part, with 4x4 end that bolts to box shaft. Member here told me 2wd wud bolt on, not true. I made it work, and its normal length, and perfect drop, at full stuff it clears by 1/2 inch I happy
yotatough
Quote from: Sparkplug on September 26, 2010, 09:04:34 PM
can you explain what you did?
Sparkplug
I had a 2wd pitman, and a normal ifs 4x4 pitman. I cut the section off of the 2wd  from the box shaft hole. I then cut off the box shaft hole off the 4x4 pitman, but left about an inch of the pitman arm on, to extend 2wd one to right length, I then beveled both edges, and did a pass on both sides in middle of bevel. Then did 2 passes each on top and bottom, and 1 hot pass on the side. Hit it with a flap disc, and this is wat I got. Ive been told that a 2wd pitman shud bolt on, but mine didnt, a pirate member said it depends on the truck, supossedly power steering ones have one that wud bolt right on, but it wudnt be correct length, u wud lose 8 percent of ur steering. If these details are not enough, lemme know, i can pm and walk u thru it
Sparkplug
rear shocks in, havent got to duals yet, movin slow and steady tho
fade
86 mini truck 18" rays
09 highlander
70 suburban
Sparkplug
bald 38s lol, yeh prob gonna, but not gonna drive on em, just need em to see wat i gonna need to cut
fade
haha they might wheel ok, dependin what your doing.
09 highlander
70 suburban
Sparkplug
Should be sttin on sum OK 36s , on the 15th, woot, then build a front shaft, and go break it
fade
what kinda tires? Only thing I'd worry about breaking is maybe a birf if your crazy hard on it. Then its just time for a upgrade
09 highlander
70 suburban
Sparkplug
36 super swampers, yeh i prob break a birf, got spares, i gonna go longs here soon, wanna see wat my driving style breaks first
4x4yota
how do you have the shocks mounted got any more pics?
Current:
Sold:
Sparkplug
Shock mounts are bolts welded to axle tube, and the bar that runs across frame on top. Ive heard the cross brace can be a weak point, But my plan was to use lower grade bolts for my shock mounts, so they would fail, and rip from axle housing, before my cross brace would be torn. I dont think it will be a problem wither way, as long as you arent jumping your truck, and run bump stops, which I have now.
4x4yota
Current:
Sold:
Sparkplug
Almost done, just gotta finosh front hanger, plate front of frame, and do duals. Borrowed my buds 35 hogs to see wat it would look like. Looks sick IMO, and not gonna have to cut too much in front, adding a longer shackle in rear also. Wat u guys think? I know the pics suck, but hell trees block my driveway, action pics to come after 15th when i get my 36's.
fade
I like it, just maybe another 2 inch's of lift or cutting. Looks almost like my old runner(the stance).
09 highlander
70 suburban
T-YOTER
ive seen this runner in person very clean sas job cant wait to get my pile going to go wheel, snow run sounds fun might go to lassen for xmas tree cutting u down?
Sparkplug
Yeh Im down, sounds like fun to me. Havent updated it in a while. I need to add a leaf to my rear pack, a longer shackle, and trim a lil bit. In the front, I need to finish puttin my hubs on and re adjusting the WB. Other than that, its all good, and I drove it today to town, and it rides nice. I gotta put my duals in sometime, but waitin on armor I think, before I put em in.
yota4x4sc
nice build up dude..i like that piptman arm u made  :turtlehead:
:usa: 92 xcab, full width, 39.5 boggers, beadlocks, 60 f arb 5.86s , 60 r spool , duals, 4.7 rear... 3.sl0, bobed , all pro 6 inch leafs f and r :usa:
yota4x4sc
