Author Topic: Is there a Max RPM for 4.7 gears?  (Read 1499 times)
GRM
  • Member since Dec '03
    • Website
« on: Jul 21, 2010, 06:47:51 AM »
I've been trying to figure out why my transfer case pukes fluid out the top of the shifter holes when driving on the freeway. It is fine at low speeds, just when I am running over 3200 rpm's in 5th gear on the highway.
The truck is an '86 mini, 22re, w56, dual ultimate, with 5.29 axle gears and 35" tires.
So far to help fix this leak I have replaced:
Shifters
Transfer Case Rebuild
Transfer Case Housing
Transmission Output Seal
Dual Case Adapter (inchworm to marlin)
and also swapped from 21 spline input 4.7 to 23 spline
The other issue I thought was strange (which spurred the rebuild) was that the pocket bearing on the input shaft was bone dry.
What makes me think it is an over-rpm issue is because I had the 4.7 transfer case in my old 4runner with 4.10 gears and 35's, with no leaks.
So my question: Is there a maximum operating rpm for 4.7 (or 2.28) transfer case gears?
Thanks for the help.
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Re: Is there a Max RPM for 4.7 gears?
« Reply #1 on: Jul 21, 2010, 07:18:57 AM »
Not that I know of. Do you have these under your T-Case shifters?
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #2 on: Jul 21, 2010, 08:43:30 PM »
the lip goes down...............
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #3 on: Jul 21, 2010, 09:10:37 PM »
I drive my truck at 80 mph on the interstate all the time and  its never leaked at all.  of course its a Marlin Crawler built tcase with all Marlin Crawler parts.
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Member since Oct '06
  • Oodelally
« Reply #4 on: Jul 21, 2010, 09:28:23 PM »
I can't say for the 4.7s but my duals are running around 3-3500rpm on the highway. 5.29s and 33s. No leaking from anywhere.
Dr.Maxwe001
  • Turtle Points: -23
  • Male Posts: 627
  • Member since Jan '05
« Reply #5 on: Jul 21, 2010, 09:50:00 PM »
:yupyup: gotta love the marlin parts
[img]http://bo
OOPS
  • Male Posts: 2,561
« Reply #6 on: Jul 22, 2010, 06:55:27 AM »
Last post Nov 22, 2004, 01:23:14 PM
by Drachota
Last post Dec 02, 2005, 01:10:33 PM
by toy4crawlin
Last post Dec 28, 2006, 08:59:01 AM
by iNfErNaL
Last post Sep 14, 2008, 11:03:56 PM
by Thomas P
Last post Jan 31, 2009, 08:35:53 PM
by Stew Padidiot
