The purpose of the sand is to support the tube, water can't do this, not in its liquid state. The results would be the same as using nothing at all. Sand isn't messsy at all, duct tap end, make paper funnel, fill tube w/sand-tamp-repeat, tape off other end, bend tube, remove duct tape, empty sand back into bag. As long as you use a little common sense when filling the tube, there shouldn't be enough sand spilt to even have enough to sweep up.A bag of sand only costs about $4, a third of what just one of those drain cleaners cost, and once your done you can use the sand to clean up spills.Heat alone wont do it either, you still need something to support the tube. With a combo of sand and heat(not red hot) you can good pretty good results using the pipe bender.
Started by Installer_Joe Parts For Sale
Started by Makohon General 4WD Discussion
Started by Tallchevy Chit Chat Camp
Started by kneedownnate Chit Chat Camp
Started by Bradku Newbie Questions
