Author Topic: 3.slow valve? found exaust is tight still looking for help?  (Read 1538 times)
lucky7
  • Turtle Points: 303
  • Male Posts: 778
  • Member since Sep '07
  • CAN'T POLISH A TURD!
Just put a motor in my 4runner and the # 1 cylinder only has 50lbs of compresion.Wondering if the valves could tighten up enough to create this?Any help would be great :confused:
« Last Edit: May 03, 2010, 11:04:30 AM by lucky7 »
2manytoys
  • Turtle Points: 490
  • Male Posts: 583
  • Member since Nov '09
Re: 3.slow valve?
« Reply #1 on: Apr 26, 2010, 11:19:21 AM »
Yes the valves could be too tight allowing loss of compression. So could bad rings, or a blown head gasket. If a valve was too tight for too long it could be burnt.
 Check your valve lash and adjust if needed. If still low, squirt a little oil in the spark plug hole and check compression again. If it goes up, it could be your rings. The oil helps them seal a little better temporarily for the test.
Crank it over with the spark plug out and see if any water blows out to check the head gasket. Is the oil milky? Any white exhaust smoke? Condensation on fill cap?
Not sure what else you checked. Just throwing ideas out there. Good luck, hope it's just a tight valve.
lucky7 [OP]
  • Male Posts: 778
Re: 3.slow valve?
« Reply #2 on: Apr 26, 2010, 07:13:08 PM »
Gonna pressurize cylinder tommorow did the oil rings are fine no water in the oil or white smoke but started out of the blue
lucky7 [OP]
  • Male Posts: 778
Re: 3.slow valve?
« Reply #3 on: Apr 28, 2010, 08:46:12 PM »
Talked to a couple of people who have broke valve springs hoping thats it.
lucky7 [OP]
  • Male Posts: 778
#1 exhaust valve is so tight its open still wondering why? :help:
superyota
  • Prestige Worldwide
  • Turtle Points: 71
  • Male Posts: 3,362
  • Member since Oct '05
  • what happened?
    • Placer County Crawlers
by any chance was the timing belt just replaced?  i got a motor for my 90 runner a while back from a guy that said he had put a new belt on it.  ended up running like crap.  after checking it all out, found that the driver bank cam was off by 5 teeth and passenger off by 2.  thats the only other thing i can think of if its not valve adjustment or valve spring.  unless its a burned up valve.
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
lucky7 [OP]
  • Male Posts: 778
pulling cam tommorow think a spring keeper broke pushing the lifter up
Last post Sep 29, 2004, 09:00:20 AM
by SWAMPER
Last post Jul 08, 2006, 06:55:17 PM
by yodaboy4life
Last post Jul 07, 2007, 12:49:27 AM
by Twisted Minis
Last post Jan 11, 2008, 06:53:44 PM
by FIREBALL
Last post Mar 14, 2008, 01:06:27 AM
by Goose
