Author Topic: 22RE wont stay running  (Read 20209 times)
exxon
  • Member since Mar '10
Re: 22RE wont stay running
« Reply #60 on: Apr 17, 2010, 07:28:16 AM »
are the wires in the connectors to the injectors visible, some time the wires back out of the connectors and won't make a circuit to the injectors, have no clue if that made sense
'86 4runner 22re
'04 TJ
'78 Ramcharger 440 35's
79coyotefrg [OP]
« Reply #61 on: Apr 17, 2010, 09:15:40 AM »
  Hey Glen Just ask your MOM...Worked last time.. :rofl2:
:bat:
79coyotefrg [OP]
« Reply #62 on: Apr 17, 2010, 09:19:16 AM »
made sense but they are all good :dunno:  I'm going to pull the engine harness and see if i can find a bad wire, if that doesnt work its getting a carburetor
79coyotefrg [OP]
« Reply #63 on: Apr 17, 2010, 07:30:57 PM »
i pulled the efi intake off, tossed it on the bench and installed a carb BUT now the carb doesnt want to act right :maddest:
I'm going to bed :(
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
« Reply #64 on: Apr 17, 2010, 07:54:03 PM »
What fuel pump you running Glen?  And did you change out the coil and dist.?
79coyotefrg [OP]
« Reply #65 on: Apr 17, 2010, 08:04:51 PM »
i installed a manual pump, but didnt change the distributor,   but that might explain why its not firing also :eek:
79coyotefrg [OP]
« Reply #66 on: Apr 18, 2010, 04:55:49 PM »
installed a 22R distributor and it fired right up problem is the fuel pumps not working i wonder if its the port i have it working off of or if the pump is bad :dunno:
:psss:  ive got it sucking on the return tube for the efi,  but i wonder if it would suck thru the efi pump :dunno:
Redbeard1
  • Turtle Points: 54
  • Male Posts: 414
  • Member since Mar '07
    • Project Pete
« Reply #67 on: Apr 18, 2010, 06:53:10 PM »
yes it will pull through the efi pump
If you dont stand behind our Troops... you can stand infront of them...
Project Pete==> http://board.marlincrawler.com/index.php?topic=43370.0
85 Toy: Built 22re, locked F, spooled R, 5.29's, R151F, MCO7 duals, Sky x-member 37 MT/R's on jack stands
 __________________________________________
||____________||____________||___TOYOTA ___||
||____________||____________||_____________||
RIP Bobby Long
79coyotefrg [OP]
« Reply #68 on: Apr 18, 2010, 07:45:57 PM »
AWESOME
Jomentum
  • Turtle Points: 3
  • Male Posts: 62
  • Member since Jul '08
  • Toyota Tech.
« Reply #69 on: Apr 21, 2010, 08:23:40 PM »
 :smack:
yOU  Carbed it ?????
just tap the fuel pump wire, run an inline resistor, = drop the voltage down = less fuel pressure = no fuel starving crawling uphill  ::)
97 T100 3.4 auto with Chevy 10 bolt/44 front, sassed 6" lift
4:56's locked front/rear 36x14.50x15's
My Truck :   http://board.marlincrawler.com/index.php?topic=62122.0
http://www.tacomaterritory.com/forum/showthread.php?t=76817
Home away from home:
http://www.tacomaterritory.com/forum/showthread.php?t=105227
Dr.Maxwe001
  • Turtle Points: -23
  • Male Posts: 627
  • Member since Jan '05
« Reply #70 on: Apr 22, 2010, 08:36:37 AM »
I want the efi wire harness
IF YOUR LOOKING OUT THE FRONT OF YOUR 4X4 AND YOU CANT SEE THEN JUST TURN ON YOUR WIPERS. BUT THEN THINGS GET ALL MESSED UP LIKE IN LIFE.
WHEN YOU GET TO THE END OF YOUR ROPE JUST THINK THAT ALONG TIME AGO  YOU WERE THE FASTEST LITTLE SWIMMER TO THE EGG
08:55:22 PM BeccaLoo24 – i like to screw things
$99 scratch and dent drill press has drilled more holes than Ron Jeremy.
http://board.marlincrawler.com/index.php?topic=48342.0
[img]http://bo
Last post Dec 10, 2004, 07:10:36 PM
by yotaboy79
Last post Dec 17, 2004, 10:59:16 AM
by BLACKDOG
Last post Mar 11, 2010, 09:55:03 PM
by SNOW WALKER
Last post Nov 11, 2016, 06:58:42 PM
by Thefishguy77
Last post Jan 15, 2018, 03:11:45 PM
by VincentVanPwn3d
