22RE wont stay running
Started by 79coyotefrg, April 12, 2010, 11:28:08 AM
my daughter and son in law bought Vman's 88 4runner its ran GREAT for the last few weeks, ran great this weekend at Superlift, then when we left it started running BAD, then got worse.   I had to tow it home from Bismark (30 miles) it starts but then quickly dies, ive checked cam timing, dist timing, fuel pump, fuel filter, compression, cat, it starts runs a bout 30-40 seconds then dies.
grounds are good, we swapped tps for a known good one,  also removed the cat because we thought it was clogged, after tweaking everything we have it running longer but it still doesnt have enough power to move  on its own.
HELP  :help: :help: :help: :help: :help:
Dr.Maxwe001
long shot here but could it be a bad clutch ?
[img]http://bo
MiniSimp
Battery connections are good at both ends?
Fuel pump pressure is good?
Fuel filter is unclogged?
*** YELLER ***
except BACON
-Jake-
all cylinders have good compression?
P-DiseToy24
PA_taco_13
coolant sensor?   mine was acting funny like that and i did lot of searching "coolant sensor" kept poping up in my searches for sporadic idle and other symptoms.   :crossed:   hope you figure it out
learn the hard way
"my dixie wrecked"
east coast crawler
V-Man
Quote from: 79coyotefrg on April 12, 2010, 11:28:08 AM
     Don't blame for this one.... :nonono:   Sorry to hear that.. :-\   This is a long shot, but any one at Superlift take a real dislike to you or the kids?   I'd check for rust or stuff in the fuel filter and/or tank.
Could have been rusty at the top and when you started filling it, the rust comes loose...Also works if you put bleach in the tank, bleach rusts the tank over night and the rust clogs the lines and filter... :dunno:
Dr.Maxwe001
:haha:
QuoteV-Man  Don't blame for this one.... :nonono:
V-MAN DID IT
[img]http://bo
Quote from: maxwe001 on April 12, 2010, 11:31:56 AM
automatic
Quote from: MiniSimp on April 12, 2010, 11:35:07 AM
batt connections good, spins it over great
dont have anything to check fuel pressure with i dont think
put new filter on and a fuel pump from another nearby (dont tell Vman) runner thats KNOWN to run very well
Quote from: ** YELLER ** on April 12, 2010, 11:44:40 AM
air tube have any leaks
ait tube??  is that the thing under the intake??
Quote from: -Jake- on April 12, 2010, 12:29:05 PM
165, 170, 170, 175
Quote from: P-DiseToy24 on April 12, 2010, 12:35:43 PM
Lose spark plug/coil wire.
all checked to be good
Quote from: PA_taco_13 on April 12, 2010, 01:29:37 PM
swapped it with another that i had, no change
Jomentum
It starts right back up after it stalls?
Does it lose Fire, fuel pressure, or injector pulse??
97 T100 3.4 auto with Chevy 10 bolt/44 front, sassed 6" lift
4:56's locked front/rear 36x14.50x15's
My Truck :   http://board.marlincrawler.com/index.php?topic=62122.0
http://www.tacomaterritory.com/forum/showthread.php?t=76817
Home away from home:
http://www.tacomaterritory.com/forum/showthread.php?t=105227
Dr.Maxwe001
Can you put a manual fuel pump on it at the carb and pour the fuel in from a drink bottle
[img]http://bo
Quote from: Jomentum on April 12, 2010, 03:59:49 PM
Joe, i just confirmed it DOES NOT have an injector pulse
i tested for power to #1 injector and both sides had power BUT when i tested between the two wires of the injector wire it had none, and when doing the pulse test it never flashed at all
i swapped the solenoid thing on the inner pass side fender for a different one and it didnt change
Quote from: maxwe001 on April 12, 2010, 04:06:46 PM
jeff, its E F I
Dr.Maxwe001
[img]http://bo
yes it starts right back up
86rustbucket
Quote from: 86rustbucket on April 12, 2010, 04:46:07 PM
AFM?
adjusted for LCE cam, been running fine for 1000 miles till yesterday, now no injector pulse :down:
Jomentum how do i fix it??
junya92toy
Try another afm, and take the intake air hose off, at throttle body,  have someone crank it over and spray brake cleaner in there and see if it runs off that.
Quote from: jerry92toy on April 12, 2010, 04:55:47 PM
Try another afm, and take the intake air hose off, have someone crank it over and spray brake cleaner in there and see if it runs off that.
we have confirmed its not getting signal to the injectors, we did this by first checking if it would run on starting fluid which it did, it ran fine till i quit spraying
MiniSimp
Computer swap? :ack: j/k, i don't know anything.
brainlessfool
does the power to the inj. come from the puter? I know it grounds though the puter.
I thought it came from some where other than the puter. bad relay?
V-Man
Quote from: 79coyotefrg on April 12, 2010, 03:27:51 PM
You Stealing parts again... :mad:... By the way how did you like the Swampers on your blue bomb at Superlift..  :driving:
Quote from: V-Man on April 12, 2010, 07:07:19 PM
me stealing parts :whistle:
i never put them on i was busy getting things ready
Quote from: brainlessfool on April 12, 2010, 06:31:35 PM
it does but doesnt if that makes sense
brainlessfool
Quote from: 79coyotefrg on April 12, 2010, 07:12:56 PM
even right now that makes no sence :boozer:
brainlessfool
could you jumper in 12+ to the injs. and see if it will run with poer on that side?
Cheesemaker
So, when it starts it sounds like your running off the cold start injector then.
Are you getting power into the inj. relay?  I'd try another ECM just for good measure.  O2 sensor?  Try getting any codes off the ECM?
