22RE wont stay running
Started by 79coyotefrg, April 12, 2010, 11:28:08 AM
exxon
are the wires in the connectors to the injectors visible, some time the wires back out of the connectors and won't make a circuit to the injectors, have no clue if that made sense
'86 4runner 22re
'04 TJ
'78 Ramcharger 440 35's
Quote from: exxon on April 17, 2010, 07:28:16 AM
made sense but they are all good :dunno:  I'm going to pull the engine harness and see if i can find a bad wire, if that doesnt work its getting a carburetor
i pulled the efi intake off, tossed it on the bench and installed a carb BUT now the carb doesnt want to act right :maddest:
I'm going to bed :(
Cheesemaker
What fuel pump you running Glen?  And did you change out the coil and dist.?
Quote from: Cheesemaker on April 17, 2010, 07:54:03 PM
i installed a manual pump, but didnt change the distributor,   but that might explain why its not firing also :eek:
installed a 22R distributor and it fired right up problem is the fuel pumps not working i wonder if its the port i have it working off of or if the pump is bad :dunno:
:psss:  ive got it sucking on the return tube for the efi,  but i wonder if it would suck thru the efi pump :dunno:
Redbeard1
yes it will pull through the efi pump
If you dont stand behind our Troops... you can stand infront of them...
Project Pete==> http://board.marlincrawler.com/index.php?topic=43370.0
85 Toy: Built 22re, locked F, spooled R, 5.29's, R151F, MCO7 duals, Sky x-member 37 MT/R's on jack stands
__________________________________________
||____________||____________||___TOYOTA ___||
||____________||____________||_____________||
RIP Bobby Long
Jomentum
 :smack:
yOU  Carbed it ?????
just tap the fuel pump wire, run an inline resistor, = drop the voltage down = less fuel pressure = no fuel starving crawling uphill  ::)
97 T100 3.4 auto with Chevy 10 bolt/44 front, sassed 6" lift
4:56's locked front/rear 36x14.50x15's
My Truck :   http://board.marlincrawler.com/index.php?topic=62122.0
http://www.tacomaterritory.com/forum/showthread.php?t=76817
Home away from home:
http://www.tacomaterritory.com/forum/showthread.php?t=105227
Dr.Maxwe001
I want the efi wire harness
[img]http://bo
