drove it all around today, still has miss with over 2000 rpm less when i step on it more cruising at 2k and up. i have been reading up, maybe the egr modulator if malfunctioning? tested the carbon canister, and it tested fine. when i apply vacuum to the egr it dies unless i stop quick.
ok so....... propane test nothin' adj tps nothin' tps is unable to be adjusted correctly. i can get either the e2-idl .85 mm or e2-vta correct but not both.
Started by BigMike « 1 2 ... 10 11 » Engine
Started by 4.3 headache Engine
Started by SLIVER Engine
Started by Caboose Parts Wanted
Started by 1980firstgen20r 1979-1983: How-To Guides
