Author Topic: No power to fuel pump??  (Read 2073 times)
yoda4x
  • Turtle Points: 84
  • Member since Jun '04
« on: Dec 06, 2004, 06:15:39 PM »
i just swapped motors from a 20r to a 22r and for some reason i now have no power to my fuel pump. i am not running a pump on the side of the engine block, just one in the tank i think. it worked fine before the swap but now nothing. if i run power directly to the pump it pumps fine, but nothing when i turn the key. anybody have any idea what could be wrong? i took apart the fuel pump relay and it looked fine. anything else i can check? please help. thanks, aaron
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: No power to fuel pump??
« Reply #1 on: Dec 06, 2004, 06:17:56 PM »
mine did the same thing,  i wired it to a dash mounted switch and use it as a theft deterant device
yoda4x [OP]
  • Turtle Points: 84
« Reply #2 on: Dec 06, 2004, 08:20:47 PM »
thats a really good idea, i think ill try that.  did you run a fuse between the battery and the switch?  i like the whole theft deterrent idea, had one truck stolen already.  thanks for the advice!
« Reply #3 on: Dec 07, 2004, 05:16:44 PM »
i run it from the "engine" fuse in the fuse block
Last post Mar 31, 2005, 07:34:15 PM
by alwayzbroken
Last post May 22, 2006, 01:36:31 AM
by jimbo74
Last post Mar 31, 2007, 09:35:41 AM
by robrub00
Last post Jun 04, 2011, 11:38:30 AM
by crawlnbeaver
Last post Mar 13, 2013, 09:54:15 PM
by AaronB
