ARP Wheel studs**RIP Great Idea**
Started by zippo, March 19, 2010, 07:29:34 PM
zippo
So i've been looking at/for wheel studs for the 85 Front Axle. "I will be using the FROR full float rear, so the same wheel studs all the way around". I know the dealership, NAPA and prolly a few others sell them, but im tired of getting broken facotry style wheel studs! I want ARP ARP2000 or CUSTOM AGE 625 PLUS wheel studs!
I'm interested in trying to get ARP to fill a custom order for ARP ARP2000 Wheel Studs who would buy em? The more I buy the easier it will be and CHEAPER! Any takers? Tell your friends, get the numbers up lets see.
Im also looking at bumping the studs lenght up to 60 mm maybe even 65mm to allow better thread engagment with the wheel spacers, etc.
Just me alone will be 24 Studs...
If you see it, its for sale.
woodfella
depending on price I would most likely be in :cool: PM me details as you get them
TacoRunner
I think they offer a Chevy stud that fits the Toyota hub, but it uses a different diameter and pitch thread.
www.4WHEELUNDERGROUND.com
[email protected]
toe
I replaced mine with Dorman Grade 8's and never had any problems since (vs OEM grade ?)
How do these studs compare to grade 8's ?
Me
zippo
#4
Grade 8 applies to standard bolts
Standard Grade
Grade 5 : Medium Carbon Steel : 85,000 - 120,000 PSI
Grade 8 : Medium Carbon Alloy Steel : 120,000 - 150,000 PSI
Metric Grade
Grade 8.8 : Medium Carbon Steel : 85,000 - 120,000 PSI
Grade 10.9 : Alloy Steel : 120,000 - 150,000 PSI
ARP material.
8740 CHROME MOLY : quench and temper steel : 180,000 - 210,000
ARP2000 : hybrid-alloy : 215,000 - 220,000
CUSTOM AGE 625 PLUS : super-alloy : 260,000 PSI
So yes. A HUGE upgrade is possible from factory style Studs. If they make or will make them.
If you are just doing the rear or IFS front axle, they make studs for a LEXUS that will work. But nothing for the 79-85 solid axle.
Quote from: TacoRunner on March 19, 2010, 11:37:51 PM
What fun is that! Its not worth doing if you have to have different sets of lugs.
TacoRunner
Quote from: toe on March 20, 2010, 12:16:16 AM
I've put Dormans at every wheel more than once, and they always gum up IF YOU DONT USE ANTI SEIZE. I hate haveing to use anti seize. They have a poorly build thread that is rough, which is why they gum up. I would love some ARP wheel studs, but I would also like them to be 1" longer. But I dont think this is worth it, but the ARP chevy ones and just change the wheel nuts. Much easier, much cheaper, much quicker than a custom order.
[email protected]
REG535
i am in depeding on the price, new arp wheel studs would be nice, front and rear for me. When i bought my yota one rear wheel stud was half broke and still is lol, new ones in the back first for me. tell us what happens, very intersted.
zippo
GOOD NEWS!... somewhat
I called and spoke with ARP about getting custom studs made! I will be emailing the stud specs to them when I get home and hope to hear something back in the morning. But the way he talked it wouldn't be a problem!
No price yet, but the more I order the cheaper they are. He said at 100-200 Pieces the price really starts to drop! So we need to start getting the word out to get the $$ down for all of us! I'lle keep you posted!
HDcruiser
That is so weird that this thread was started. I was going to call ARP tomorrow and ask about custom Wheel studs. The wheel stud i am currently using is a Dorman # 610-264.1....   its a M12-1.50. The problem im haveing is i just bought a set of T/R beadlock wheels and the center of the wheel is thicker than my old wheels. I can only 6 full rotations on the stud when torqued down to 80 ft pounds. I need this stud to be a 1/2" longer to get to get more of the lug nut on the stud. Im looking to get 12 and possible another 12 for a friend. I will get a hold of him tonight.
HDcruiser
Can you PM me the specs, if its what im looking for, i will take 24.  :crossed:
zippo
Alot of people have this problem. It is also a problem with wheel spacers. I am going to have them extedned the thread  by prolly 10mm/0.39inch. Perhaps a even a little more. I'lle keep you posted and post the specs i have and information exchanged with ARP.
HDcruiser
86toyota
interested. Let us know what they what they tell you after you send them the specs
T86OTA
REG535
24 also, when they a lil longer would it affect how the nut from going all the way down? dumb question lol. just curious or would it be the same as the factory length with the nut on them.
zippo
To gain full affect you would need a lug from ARP made from the same material, prolly something like 8740 Chrome Moly. It would be an open nut and size wouldn't really matter. The key in my mind is the wheel spacer and it not protruding into the wheel.
REG535
oh k, so a lug nut too? why open nut i kinda like them closed? like the stock ones. and if you didnt have wheel spacers would it matter for us that dont
86toyota
wouldnt you need 36 studs...24 spindle studs + 12 more wheel spacer studs?
T86OTA
zippo
Any lug nut with the proper thread pitch should work. Many people make them with different lenghts that would work. I am unsure if ARP makes "Acorn" ones or not. I will ask
Quote from: 86toyota on March 22, 2010, 06:33:55 PM
I'm not sure if you can even change the wheel spacer studs. I plan on using ARP studs/nuts to hold the spacer on and then the spacer nuts on the tires.
HDcruiser
Zippo, this is what im currently using. I need the shoulder lenth to be the same, the threads is what i need to be longer. If the ARP studs you are requesting is like this but longer, im all over it..
 Type: Serrated Stud
Thread: M12-1.5
Knurl Dia.: 14.46mm
Length: 52.5mm
Shoulder Length: 25mm
Head Code:
Brand: Dorman - AutoGrade - Bagged
86toyota
T86OTA
zippo
Yeah that looks like the specs i miced. I will post it when i get home.
HDcruiser
Sweet, i was able to get the picture in the post.. the picture is almost the actual size. I have the stud in my hand  right now..
zippo
When i messaured it it got a Curl of 14.33. Other then that they are the same.
TacoRunner
Sweet  :yesnod: I wishing I had done more with this a year ago when I was messing with my junk. Personnally I want new studs that are .750" longer with an open tapered nut.
Sign me up for 24 of them bad boys.
[email protected]
zippo
If it goes through, Maybe we can work out a deal :-p
Quote from: TacoRunner on March 22, 2010, 07:10:57 PM
19mm that would be a huge increase! I'lle have to check and make sure it will clear everything!
Tacos and tundras need longer studs in the front too, they're ridiculously short!  I'd like to do the taco front brake swap but would want studs 1/2-3/4" longer.
zippo
Im not sure if Tacos and Tundras use the same stud. I think it has a shorter sholder 25mm. If i am able to get the Solid axle stuff made ille see about getting others.
toe
Quote from: zippo on March 22, 2010, 06:16:58 PM
Actually, I'd want the lug nut to be weaker so it strips out or breaks first.......
It's a lot easier to replace the nuts than the studs...........
Me
zippo
Here are the specs I got and am send to ARP. I will be upping the thread length from 24.5 to 34.5. I'lle let you know something when i do!
Cheesemaker
Just a thought.  Why don't ya give Marlin a call, and see if he is willing to make the order, and sell them?  That way, he can do the order for larger quantities, and get a cheaper price.  He may already have some ideas in mind too!!   :dunno:
