i just ran a wire from the fuse panel under the dash to a toggle switch to the pressure switch,if you pull it from a circuit that is only hot when the key is on you dont have to worry about accidentally leaving your clutch engaged all nite and killing your battery.you cant use it without the engine on anyway
Perfect, thanks for the help!
not a problem, i got all my info from yotatoughi didnt know a thing about it 'till he showed me
Or if that doesn't work, you can take the bracket off and drill that hole out a little bit to get even more play.
That's probably what I'm going to have to do. Not looking forward to removing everything I just installed
Started by trax28to Parts For Sale
Started by RunnerRunner96 General 4WD Discussion
Started by Dcal714 General 4WD Discussion
Started by PeterPaul383 Toyota Pickup/4Runner Tech 1979-95
Started by Lewis Hein Toyota Pickup/4Runner Tech 1979-95
