Author Topic: Cold Weather Issues  (Read 1383 times)
Anti404
  • Male Posts: 3
  • Member since Oct '04
  • You gotta crawl before you walk
Cold Weather Issues
« on: Nov 30, 2004, 04:09:14 PM »
So its November in Colorado. The temperature is officially low for the next few months, and my 22R is complaining. My gas mileage has dropped from 12.5 average mpg to 10.0 mpg. Unacceptable. Here are the symptoms: Excessive backfiring, exhaust smells of gasoline, and of course gas mileage. This leads me to believe that the engine is running rich. After briefly consulting the 'ol Toyota Truck Repair manual, I dont see an easy way to adjust the mixture for this altitude and temperature. Carburetor is stock, as are ignition and fuel systems. Recently, I  converted to a DOA Racing Engines dual row timing chain, and have recently checked the timing. Spark plugs and wires inspected and gapped properly. I will admit to a few exhaust leaks... So... what systems should I adjust/repair/replace to solve the problem? Thanks for the insight.  :beerchug:  :beerchug:
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Cold Weather Issues
« Reply #1 on: Nov 30, 2004, 04:55:30 PM »
check your cam timing,  sounds like you got one tooth off when you put your new kit on,  make sure you have coolant running thru the choke
it is a coolant heated choke ???
Last post Jan 25, 2008, 08:08:53 AM
by mudmaster
Last post Dec 27, 2009, 06:10:03 PM
by 1990GT50
Last post Feb 05, 2011, 09:18:39 PM
by twistedtoy92
Last post Apr 21, 2012, 10:40:16 AM
by Bradtoyotas
Last post Dec 02, 2021, 10:32:51 PM
by bigarms23
