Hey I just picked up a yota and have been putting some work into it.
The only problem I have left is that the thing will not start when it's cold (the engine, not the outside temp). In the mornings, I haveto go outside and tun the key and crank it once, off, crank it again, off, again, and again and again forever. If I were to just crank it nonstop (hold the key in start position) then it wouldn't ever start. After I crank it enough to start warming up (like 10-15 min), BAM, all of a sudden one crank it will fire right up and then it starts up first crank the rest of the day it's fine. While cold, right when I crank it, you can hear it sputter a tiny bit like it barely fires but cant start. Then it just makes the cranking sound without sounding like its gonna start if you continue cranking.
I had researched the problem quite a bit and seemed prety sure it was a cold start injector. I pulled the old one which was all gunked up and replaced it which cut my start time down to about 5min of cranking on and off.
Then i replaced the coolant temp sensor hoping that would solve the problem, to no avail.
What else could be the problem. The motor runs great other than this and as I said, once It gets started it will start up right away the rest of the day. In the mornings it's straight up embarassing. I definately need a solution so please help me out. Im gonna be working on it all day tomorrow and really need to solve it before christmas. I have ruled out the typical suspects, so what are the rest?
Update: Alright well I have tested everything and there is no power making it to the switch. Its leaving the ignition switch via the black wire with white stripe when I crank it, I can follow the ignition switch wire to a relay and then into a clifford alarm system. I attached a wire directly from the ignition switch wire to the green wire at the injector timing switch, but I feel like the green wire is going to the ECU??? There are two wires going to the injector timing switch, the brown wire tested as a ground and the green as 0 volts. Once I hooked the hot lead up when I cranked, the green wire showed 12 volts (makes sense b/c of hot lead) but the brown wire changed from a ground to a positive 12 volts as well. Is this my problem?
I already suck at wiring and this is killing me.
PS- I have a 30pack for anybody in San Luis Obispo who can help me fix this
- bonus 12pk if you can remove my alarm successfully
