Author Topic: Rancid Smell in 4wd  (Read 3387 times)
lilbuddy
  • Dried Fruit Warrior
  • Turtle Points: -234
  • Male Posts: 5,720
  • Member since Aug '04
  • Hella....
Rancid Smell in 4wd
« on: Nov 28, 2004, 07:50:26 PM »
Ok, ive got a weird problem... When I am in 4 low and I press on the gas, there is a very very bad smell that comes inside the cab and can even smell it 10+ feet away from the truck. Its only when im in 4 low though. When I am in 4 high it doesnt do it but it smells even worse when I switch gears in 4 low. Its so bad that I have to stop and get out sometimes. You guys have any idea what it might be? My friend said that it could be my clutch going out...but it is also pretty new. I need it fixed...
Chris
RIP Kyota.... you are the man
GET IT!!!
Mike D
  • Turtle Points: 122
  • Male Posts: 1,902
  • Member since Jun '04
  • MMMMMMMMMM........
Re: Rancid Smell in 4wd
« Reply #1 on: Nov 28, 2004, 07:53:22 PM »
well clutches have a certian smell and if you got a stock clutch then don't expect more than 5 months if you drive it alot
87 runner, 4" trailmaster lift, 33" TSL/SX, 5.29's V6 e-locker, 22re that cost too much
DontStall Rockcrwl
  • Turtle Points: 90
  • Member since Aug '03
« Reply #2 on: Nov 29, 2004, 09:43:27 AM »
gear oil smells pretty rank. dont know why it would only smell in 4 whell low though. doesnt make much sence. maybe its because your going a lot slower so you can smell it eaiser   :-\\
You have all gotta be jealous how close i live to the 'Con
  • Turtle Points: 2158
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
« Reply #3 on: Nov 29, 2004, 10:26:49 AM »
Is it occuring only in 4low or also in 4high? Or could it be that since in 4low your vehicles speed is slower so the smell is able to "stay" with the vehicle - so in 4high you dont smell it as much?
It won't be your clutch because thats working just the same as in high or low ranges, 2WD or 4WD. The only thing is if you are using 40" tires with 3.90:1 diff gearing and are slipping your clutch everywhere you go in low range because your first gear idles at over 6 mph :ack:
I was thinking about your driveline. Are the splines or the yokes over-greased and once you use 4WD it throws grease all over the place including your exhaust pipe and then it burns off......
lilbuddy [OP]
  • Male Posts: 5,720
  • Hella....
« Reply #4 on: Nov 29, 2004, 03:48:51 PM »
I think you guys solved the problem! There is a little leak of gear oil comin out of the tcase and it throws it on the driveline. It was smelling so bad that my dad had to get out and ride with my brother..it was kinda comical by then. Since we narrowed down that, how do i fix the leak? Couple people told me its like a 2 dollar gasket that goes there but is it simple?
Yes it only does it in 4 low for some reason. Even when i am going slow in 4 high i dont smell it. Its very weird.
GET IT!!!
Mike D
  • Male Posts: 1,902
« Reply #5 on: Nov 29, 2004, 03:50:44 PM »
where is is leaking at? the driveline flange  :dunno:
brainlessfool
  • Turtle Points: 2730
  • Male Posts: 4,207
  • Member since Jun '02
    • Buy me a cigar
« Reply #6 on: Nov 29, 2004, 04:02:11 PM »
gear oil huh? well that blows my hitting a skunk idea!
  • 511:1 Club
« Reply #7 on: Nov 29, 2004, 04:19:25 PM »
Hopefully it is just the front output 4-bolt housing.
« Reply #8 on: Nov 29, 2004, 06:08:46 PM »
i was going to suggest the cat, but if theres a lube leak,
dude,  does it smell like rotten eggs?
burning plastic?
deadskunk trapped between cat and muffler? :ack:
DontStall Rockcrwl
  • Turtle Points: 90
« Reply #9 on: Nov 29, 2004, 08:10:09 PM »
check fill plug and output flange. your seals could have gone bad in there. i tell you one thing though... you think gear oil smells bad... try burnt gear oil  :reg:
lilbuddy [OP]
  • Male Posts: 5,720
  • Hella....
« Reply #10 on: Nov 29, 2004, 09:09:06 PM »
It smells like a mix of dead skunk, rotting cat on the side of the road and rotten eggs. I took a look at the muffler and there is oil stains all over it. So I am guessing that it is gear oil flying all over the place.
Yes it is leaking right out of the driveline flange i guess. Its right where the rear driveline comes out and everytime I go outside and look at it, there is a little oildrop coming off of it.
GET IT!!!
« Reply #11 on: Nov 30, 2004, 09:56:42 AM »
bad rear output seal, and possibly rear bearing
lilbuddy [OP]
  • Male Posts: 5,720
  • Hella....
« Reply #12 on: Nov 30, 2004, 03:27:01 PM »
Thats no good if its the rear bearing.  :shake_head: especially the fact i have zero money and no job at all (still too yong). Too bad duct tape and wire wont fix it this time...
GET IT!!!
« Reply #13 on: Nov 30, 2004, 04:14:05 PM »
um i dont think the rear bearing is that big a deal to fix,  could be your flange nut is loose too
lilbuddy [OP]
  • Male Posts: 5,720
  • Hella....
« Reply #14 on: Dec 01, 2004, 03:24:20 PM »
Thats good news. Ill take a look at it later. Thanks guys  :beer:
GET IT!!!
Mike D
  • Male Posts: 1,902
« Reply #15 on: Dec 01, 2004, 03:29:24 PM »
THE TOURQUE IS 91FT LBS BY THE WAY
Last post Sep 19, 2005, 01:42:06 PM
by Rocksurfer
Last post Oct 04, 2006, 11:15:33 PM
by BLACKDOG
Last post Dec 21, 2006, 06:23:15 PM
by 79coyotefrg
Last post May 09, 2007, 08:06:54 AM
by SACD_Runner
Last post Jul 27, 2020, 09:57:41 AM
by rustiga
