Author Topic: towing my truck with a 5.3 chevy  (Read 4410 times)
yota_krawler
  • Cody Hunter
  • Turtle Points: 5
  • Male Posts: 3,379
  • Member since Oct '06
  • proud parent!!!
« on: Jan 10, 2010, 10:22:34 PM »
So i am already tryin to prep for the round up. I know its far away but money is tight and I do not want to miss it again. Anyway I do not have a tow rig but I have a trailer. My buddy is going to use his truck to pull mine.
He has an 01 chevy 1500 4x4, stock, auto, it has the 5.3 in it. Not sure specs or anything on it but can it pull my pickup? what do i need to do to get it to pull? I know we wont break any records getting there but anything helps
BikerTrash
  • Male Posts: 207
  • Member since Aug '06
Re: towing my truck with a 5.3 chevy
« Reply #1 on: Jan 11, 2010, 04:24:09 AM »
I would hope it can, Towed my 4runner around for years with a ford with a 4.6 untill I bought my dodge.
There is a fine line between clever and stupid, I just wish I knew when I crossed it.
84 4runner
02 Suzuki V-Strom
95 Honda 1100C1
06 Ram 2500 4x4
(please note, listed in order of preference)
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
  • Member since Sep '04
« Reply #2 on: Jan 11, 2010, 09:00:46 AM »
It will work.  I just went to TSF this saturday, and everybody there that had towed their rigs there was using a Chevy 1500 2wd/4wd.  Just don't use overdrive and take it easy and you'll be fine.
red
  • Turtle Points: 199
  • Male Posts: 1,616
  • Member since Jan '05
  • irish redhead texan, interesting combo
« Reply #3 on: Jan 11, 2010, 09:46:05 AM »
yep take it outta od and it should be fine
read and comment :whip:
USAF EOD tech
Yota-Freak
  • Male Posts: 469
  • Member since Jul '08
  • Pass tha' whiskey and that rot gut Shine.
« Reply #4 on: Jan 11, 2010, 09:57:01 AM »
these newer 327's are garbage when it comes to the gaskets and whatnot...but do pack a bunch in power. probably tow two truck...might have problem on the hills though
COToy91
  • Turtle Points: -21
  • Male Posts: 1,241
  • Member since May '07
  • Rollin on 37's
« Reply #5 on: Jan 11, 2010, 10:06:45 AM »
it is all i have ever used. If it has tow haul mode use it, it will prolong shift points and pull better. Like everyone else has said, dont use o/d. It will be very slow on the passes, but mine has over 200,000 and still tows fine.
yota_krawler [OP]
  • Cody Hunter
  • Turtle Points: 5
  • Male Posts: 3,379
  • proud parent!!!
« Reply #6 on: Jan 11, 2010, 02:51:30 PM »
cool thats what i wanna hear. I was thinkin about puttin airbags on it, tranny cooler, and trailer breaks. Should be fine right?
88_Pathy
  • Turtle Points: 65
  • Male Posts: 1,251
  • Raised suspension
« Reply #7 on: Jan 11, 2010, 03:19:04 PM »
It will be fine.
axled89
  • Turtle Points: 296
  • Male Posts: 2,526
  • Member since Jan '09
« Reply #8 on: Jan 11, 2010, 04:04:59 PM »
x6.
i love oregon wheelin.
COToy91
  • Male Posts: 1,241
  • Rollin on 37's
« Reply #9 on: Jan 11, 2010, 04:35:54 PM »
I have trailer brakes, it wont sit level so you could add bags if you wanted. Tranny cooler is built in
Cheesemaker
  • Male Posts: 4,525
« Reply #10 on: Jan 11, 2010, 04:40:17 PM »
Probably a good set of overloads would be cheaper and just as good.  Good call on the t-cooler and trailer brakes.   Factory tranny coolers run through the radiator, but best bet is to get an external one with a electric fan on it.  Works way better than a factory setup.  I've seen people plug a external on the return side of the factory lines.
Look for a shift kit or a programmer to make it shift better.  The firmer the shifts the less wear to the bands.
yota_krawler [OP]
  • Cody Hunter
  • Turtle Points: 5
  • Male Posts: 3,379
  • proud parent!!!
« Reply #11 on: Jan 11, 2010, 09:28:55 PM »
so i found out by research that the gvwr is 8600lbs with 4.10 gears. so that might work
also we need to put a hitch back on it, the person before him took it off. So i found one that is rated for 10,000 and its 200 bucks, is that to much hitch? And what are good break controllers???
Dan The Man
  • Male Posts: 23
  • Member since Dec '09
« Reply #12 on: Jan 14, 2010, 03:51:35 PM »
$200 seems like a lot unless its an aftermarket hitch. Not sure what the stock hitch is rated for, but we've got 2 or 3 stock ones laying around. Where are you located?
As for the brake controller. The Tekonsha Prodigy is one of the best.
'91 Wrangler - 5.7L, 4L60E, NP241, HP D44, Ford 8.8, 4.88's, 36" TSL's
'02 Chevy Ex-Cab
red
  • Male Posts: 1,616
« Reply #13 on: Jan 14, 2010, 05:51:32 PM »
the 'prodigy' or 'p3' brake controllers are my favorites but not cheap.
USAF EOD tech
toyotanner
  • Turtle Points: 66
  • Male Posts: 1,958
  • Member since Oct '07
  • low n slow
« Reply #14 on: Jan 14, 2010, 06:27:02 PM »
i have a 99 chevy 4x4 std cab auto 5.3 vortec w/ K&N intake, superchip, and exhaust... and it tows my 1st gen no problem
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
« Reply #15 on: Jan 14, 2010, 10:45:37 PM »
My dad has towed my truck on an equipment trailer a few times with his '03 tahoe, no problem.
              -Ronald Reagan
83yota
  • Turtle Points: 372
  • Member since Mar '04
  • rollin my nike's
« Reply #16 on: Feb 01, 2010, 05:55:56 PM »
as far as the brake controler the prodigy is the best (IMO) but if your putting it in your buddies truck I dont think i would spend that kind of money for 1 trip unless he is going to go half with you or you get to keep it. the truck will do fine just take it slow and easy
sweetmeat
  • Turtle Points: -13
  • Member since Dec '08
  • Friends don't let friends join the sierra club
    • Wrecked4x4
« Reply #17 on: Feb 01, 2010, 06:25:23 PM »
Alot of throttle and a gas card you should be just fine :beer:
A&G Motorsports Class 1 #1553 Crew Member
Wrecked4x4.com
toyotanner
  • Turtle Points: 66
  • Male Posts: 1,958
  • low n slow
« Reply #18 on: Feb 02, 2010, 12:25:00 AM »
drawtite brake actuators are my favorite i used to install them and its a sinch
Last post Aug 28, 2005, 10:28:21 PM
by *FFC*
Last post Feb 10, 2007, 08:43:04 PM
by alwayzbroken
Last post Feb 14, 2008, 01:04:11 PM
by Blingn
Last post Jun 23, 2007, 04:47:31 PM
by fatt_matt
Last post Jul 25, 2007, 01:38:07 PM
by krawler76
