Axle Grease
Started by GONZO97, January 06, 2010, 07:44:37 PM
GONZO97
Hey guys just wondering what you guys have used in the past to clean up old grease covered axles, engines, ect.? What techniques have you found most useful?  :cool:
1997 4Runner Limited 3" lift on 31 M/Ts-Traded
http://board.marlincrawler.com/index.php?topic=61054.msg749103#msg749103
1995 Xtended Cab SAS on 35's Dual Cases-Sold
1991 4Runner SAS on 33s RUF 63's in the back Bilsteins all the way around, 5.29s front and rear Detroit locked Front and Rear http://board.marlincrawler.com/index.php?topic=65180.0
1988 4Runner 3.0 V6--SOLD
http://board.marlincrawler.com/index.php?topic=97592.msg1086573#msg1086573
1996 Toyota 4Runner 3.4 V6 3" OME Lift Springs 33" Duratracs
The Build:
Coming Soon
-Jake-
xylene and a wire brush and lots of brake clean the real stuff not the knock off
Steve_925
oven cleaner!! works awsome and its not too expensive
UA 342
STEAMFITTERS
GONZO97
Never thought to use oven cleaner...i was using a heavy duty degreaser and man is that stuff thick i guess i need a heavy heavy duty degreaser. because that stuff just wont come off
The Build:
Coming Soon
Volcom
I just scrape the old grease & oil off with a putty knife or screwdriver and use brake cleaner.  If it's really bad, they end up in a solvent tank with a brush.
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
BlackRock
GONZO97
Volcom what do you soak them in? Thought about going to the car wash real early and using theyre pressure washer and just blast everything but grease would be flying everywhere!
The Build:
Coming Soon
Borrow a steam cleaner, or get together with a group of friends and split the rental cost as many ways as possible  ;)  You'll still want to scrape off the heavier stuff first, but with some purple power (or any good engine cleaner) the stuff will blow off.
PhantomD aka Zach
I would suggest a high pressure wash THEN use the expensive chemicals...
I had an axle that was COVERED with grease and oil and a simple car wash worked wonders... I was 2-3" away though...
a simple wipe down with some simple green would clean it up very nicely.
-Zach
3rd Gen Extra Cab, Dual Cases, E-Lockers
GONZO97
Thanks zach yeah i plan on borrowing my uncles pressure washer which is pretty heavy duty so hopefully that get the majority of it off
The Build:
Coming Soon
