equal and opposite... the tissue or anything else, can't push back any harder than you're pushing on it, otherwise one of you will move. F=ma
Holy crap How do you guy's com up with all of this I wish I had the motivation to learn this crap. I have enough trouble with algebra
all i gotta say is... 2 and a 1/2 gear everyone i knows wishes they had one ! thats what dual trannys will give you .. i like the idea of pretty much half gears.. theres time that you need a half gear because one is to low and the other is to high..
Lets assume 37s, so the torque is 1.5417ft*2500lbs=3854 ft-lbs.
I know that for years Downey and Northwest Offroad have both sold conversion bellhousings for toyota transmissions to adapt to domestic v-6s, and v-8s. As you read the description in their catalog though they will even tell you that they dont' really recommend it as the toyota transmissions aren't up to the task of taking that much torque. They will even tell you that they only sell them because people will buy them. At the same time they sell adapters to put Yota t-cases behind domestic transmissions without saying a word. Hmm, wonder if there is something to that?
Hey hudlenutz or blackdiamond, maybe you guys are better at this as I didn't do so well in my Statics class when we learned about centroids and center of mass, but I bet if we assume like a 60/40 weight distribution, and wheel bases are around 110", so maybe we could assume that this mass is distributed over like a 130" distance, then we could see how much torque would be required to wheelie the truck about its rear axle.Assuming nothing fails, if I bolted the rear axles down to the ground, and then put the truck in 1st gear at 1,047:1 and just let it idle in gear, I wonder how much torque would be acting on the rear axle by the time the front of the truck is at a 45 degree angle off the ground.If I was back at home I could just pull out my Statics book and flip to that section, and I am helpless over here
Wow, that is pretty cool. I did learn about moments but I thought it would involve some trig and the center of mass, since the torque would be highest at 45 degrees and zero at 90 degrees...None the less, thats pretty cool. So even with 100% traction the axles may only see about 16k ft-lbs of torque dispite that the engine is only putting out about 1/5th its potential
Ah dang, you got me on that one. Yup, it would be the greatest at the horizontial.Well it is just past 1am Monday morning here. I think learning so much about Japan and trying to catch up to everyone's language has caused me to loose some of my mechanical touch. I have been killing myself lately
Hey all. I just wanted to let EVERYONE KNOW THAT THE TRANSMISSIONS ARE STILL BEING WHEELED>>>AND HARD
if you think about it dual trannys is alot simpler.. all you have to do is make the adapter ( 2 pieces of plate and a tube) and bolt the 2 trannys together.. now with dual cases you have to tear down a case modify shift rods and all kinds of other stuff.. the only reason dual trannys doesnt look as simple to some is because its not a normal thing.
If I put the dual cases and 4.7's in I'd be over 695:1 with 4.10's in 1/1/L/L
Started by Tice General 4WD Discussion
Started by toy87 Parts For Sale
Started by Hottrod81 New Announcements and Info
Started by crawlerdan Parts For Sale
Started by 66cobra General 4WD Discussion
