Anyone runnin' a Budbuilt flat belly?
Started by Tice, April 24, 2006, 07:50:32 PM
Tice
Got mine installed along with the dual cases last weekend :yupyup: and had to cut a lot of the tranny tunnel out. Not a big deal, but in an effort to save some of the floor support I left just enough to clear the flange on the output shaft of the rear case. I left about half inch of clearence.  Thought it would be enough, but upon driving it for the first time yesterday I found that the tourqe ( what little there is) from the engine make the whole crossmember and skid along with the tranny and cases move up about an inch.  I know that the tranny and such flex's on acceleration but the cross member seems to be pretty flexable, which I don't like!!! So does anyone here run one and are you having the same problem? Have you found a cure for it? I thought about trying to strenghting it with some square tubing on the front and back of the top ( where the case bolts to it) to help control the flexing. Sound like a good idea? Thanks for any help. :beerchug:
I don't need a winch, I wheel a TOYOTA!!!!!!!
www.wheelingarizona.com
Tice
Here's a pic of the floor I cut out.
are you sure its not just the tcase mounts  flexing :eek:
i need a 1 or 2 inch body lift  :down:
Tice
Pretty sure!! :disturbed: I'm going to have a friend watch it for me to see what all is moving.
Volcom
Nice, you have an Easy button built right into your front seat  :greengrin:
It's a TV commerical if you don't get it.  :psss:
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Tice
Quote from: Volcom on April 26, 2006, 01:33:37 PM
I made it so the Heep guys could follow us Toy guys!!! :yupyup:
IronClad
id check yer motor mounts  that would cause alot..
Annihilation  Fabrication
Do you need a Hammer?
