Author Topic: Tylers 1981 Toyota Trekker Build  (Read 54557 times)
GotMyYotaBack
  • Male Posts: 201
  • Member since Apr '09
  • "I like Turtles" Google it
Re: Tylers 1981 Toyota Trekker Build
« Reply #30 on: Jan 20, 2010, 08:55:37 AM »
should post up on http://toyotatrekker.com .. they LIKE Trekkers too  :)
Yea, thanks Corey I meant to put it up over there too.  :smack: I will.
Trekker Build- http://board.marlincrawler.com/index.php?topic=64943.0
Aoccdrnig to a rscheearch at Cmabrigde Uinervtisy, it deosn't mttaer in waht oredr the ltteers in a wrod are, the olny iprmoetnt tihng is taht the frist and lsat ltteer be at the rghit pclae. The rset can be a total mses and you can sitll raed it wouthit porbelm. Tihs is bcuseae the huamn mnid deos not raed ervey lteter by istlef, but the wrod as a wlohe.
So dont tell me I spelled it wrong! You knew what I ment.
GotMyYotaBack [OP]
  • Male Posts: 201
« Reply #31 on: Jan 20, 2010, 08:57:55 AM »
Edit:  bickering removed :thumbs:
Look you two, if you wanna play at my house you play by my rules. Now CAN IT and play nice! :)
« Last Edit: Jan 20, 2010, 10:36:23 AM by 79coyotefrg »
dropzone
  • Turtle Points: 7
  • Member since Feb '07
  • Drive a 1st Gen
« Reply #32 on: Jan 21, 2010, 01:35:21 AM »
That's how I woulda reacted today if I had gotten a Trekker and I'm 40. Kid, you did your Dad proud with that response.
I was 40 when I got my Trekker :greengrin:
great father/son project...
81 Toyota Trekker 221:1
trekkerpaul
  • Member since Aug '09
« Reply #33 on: Jan 21, 2010, 07:58:42 AM »
Looking good Dan :clap2:
GotMyYotaBack [OP]
  • Male Posts: 201
« Reply #34 on: Jan 23, 2010, 10:34:14 AM »
Took it to Andy's last night and with his help, got the front end out and ready for rebuild. Steering gear box is out, and we just need to trim all the crap off the housing and the frame. I need to figure out how to get that stinking steel sleave out of the rear leaf spring bushing with out hurting the rubber, we tried pressing it ou no luck  ??? Then Andy was gracious enough to cut up a good saw blade, so we could cut the bushing from the inside. But this steel is like, harder then Diamonds, and wont cut. So Any ideas?
So this is the culprit, I'm doing RUF and this is the bushing that goes up front in the hanger, its OD is larger then the standard aftermarket bushing, and its ID is to small, if I could get the sleave out, I would be golden with the new 18mm ft greasable bolts.
GotMyYotaBack [OP]
  • Male Posts: 201
« Reply #35 on: Jan 23, 2010, 10:39:57 AM »
This is the tool Andy made, its cuts through anything but, this sleave.
Then we  :beerchug: :beerchug: :beerchug: and bench raced. Thanks for your help Andy.
skinneykansas
  • Turtle Points: -2
  • Male Posts: 115
  • Member since Oct '09
« Reply #36 on: Jan 23, 2010, 11:23:41 AM »
i had to do the same thing with my ruf. if you have a press i would try and grease that little metal sleeve, then get a socket or something that just fits the diameter of the sleeve and put a piece of tube or something on the underside of the bushing to make sure you dont press it out as well. thats how i got mine out
93 2wd stock toyota
GotMyYotaBack [OP]
  • Male Posts: 201
« Reply #37 on: Jan 23, 2010, 11:36:25 AM »
Yea, we gave that a real college try, almost bent the vice handle, with a jack handle for leverage. Good news however, Pirate RUF FAQ page 7 says that the older springs dont have the sleave, so the springs that are in the back of the truck should be okay, we had tried to use a set that Andy had laying around. So back to the shop in a few to check. Thanks for the $.02
skinneykansas
  • Turtle Points: -2
  • Male Posts: 115
« Reply #38 on: Jan 23, 2010, 11:38:39 AM »
yeah thats what happened to me as well i tried using 4runner springs fist which were pretty clapped out, then took the springs out of my 83 and its just regular bushings. good lookin truck keep up the good work your son is lucky
93 2wd stock toyota
GotMyYotaBack [OP]
  • Male Posts: 201
« Reply #39 on: Jan 23, 2010, 11:46:18 AM »
Thanks, I think we are both pretty lucky.
GotMyYotaBack [OP]
  • Male Posts: 201
« Reply #40 on: Jan 24, 2010, 11:22:08 AM »
Front Hanger is in, Springs are built and In. Rear end is out and fenders are cut!  :greengrin:
GotMyYotaBack [OP]
  • Male Posts: 201
« Reply #41 on: Jan 24, 2010, 11:25:23 AM »
These are the new old rears vs. the old fts, the old ones were inverted on the truck. New rears have 3 mains, 1 extra from other set, and 1 beefy bottom spring from a lifted spring pack. I have no idea how tall it will be.
  • 96ZJ v8
  • Turtle Points: -415
  • Male Posts: 4,823
    • Buy me a drink
« Reply #42 on: Jan 24, 2010, 11:27:23 AM »
oooo let me know how u like them... i may change my front springs.
GEARED UP
  • Turtle Points: -5
  • Male Posts: 74
  • Member since Jan '10
« Reply #43 on: Jan 24, 2010, 03:20:01 PM »
lookin good homo !!!
GEARED UP
  • Turtle Points: -5
  • Male Posts: 74
« Reply #44 on: Jan 24, 2010, 03:21:36 PM »
now let's see  pics !  :thumbs: :thumbs:
GotMyYotaBack [OP]
  • Male Posts: 201
« Reply #45 on: Jan 27, 2010, 12:03:01 PM »
Nuthin to see yet, Im rebuilding and gearing axles this week, at the shop. I think we are skippin Tahoe, so I can get this thing done and rolling this weekend.
GotMyYotaBack [OP]
  • Male Posts: 201
« Reply #46 on: Jan 27, 2010, 12:04:26 PM »
By the way, how are things going hanging out in front of the Home Depot? :)
studentwheeler
  • Turtle Points: 121
  • Male Posts: 382
  • Member since Feb '06
« Reply #47 on: Jan 27, 2010, 10:55:05 PM »
 :laugh:
GotMyYotaBack [OP]
  • Male Posts: 201
« Reply #48 on: Jan 28, 2010, 07:25:38 PM »
 :greengrin: Okay, took some time off today to build 2 diffs w/ 529's got to the shop and the install kits didnt show  :shake_head: So I took the dau off for nuthin. Decided to do some of the clean up work that I had planned for Tyler for Saturday, I guess he gets lucky again.  :shake: I also got all the gussets in and the upper truss, cleaned off ll the old bracket slagg, and painted the housing. Some welds I am proud of others are well,  :smack: They all look worse in the pictures then in real life  :gap:
I did save the other knuckle for Tyler to do, so he can "appreciate" 30 years of grime.  :thumbs:
Jud
  • Scumbaggin
  • Turtle Points: -261
  • Male Posts: 3,067
  • Gettin it since 1990
« Reply #49 on: Jan 28, 2010, 08:20:17 PM »
Looks good dood
"bout tree fiddy"
GEARED UP
  • Turtle Points: -5
  • Male Posts: 74
« Reply #50 on: Jan 31, 2010, 08:58:01 PM »
you guys runnin the bogs? little ap
Jud
  • Scumbaggin
  • Male Posts: 3,067
« Reply #51 on: Jan 31, 2010, 10:31:45 PM »
Is this Antonios Taco Wagon making an appearance in here?
"bout tree fiddy"
GotMyYotaBack [OP]
  • Male Posts: 201
« Reply #52 on: Feb 01, 2010, 12:59:43 PM »
Yea, thats AP his son. They are looking for a Fuel Inj Runner, keep your eyes out.
AP, no those boggers are on a buggy customer.
Jud
  • Scumbaggin
  • Male Posts: 3,067
« Reply #53 on: Feb 01, 2010, 04:13:58 PM »
1st or 2nd gen runner?
"bout tree fiddy"
GotMyYotaBack [OP]
  • Male Posts: 201
« Reply #54 on: Feb 02, 2010, 04:42:53 PM »
Either, running and cheap  :greengrin:
GotMyYotaBack [OP]
  • Male Posts: 201
« Reply #55 on: Feb 02, 2010, 04:48:25 PM »
Made some progress this weekend. Tyler and I went to the shop to assemble the axle, expecting the 3rd to be done, it wasnt they were slammed, so we loaded everything up and went to Royce's to get some help setting it up. Didnt get home til late Sat. So bright and early Sunday we assembled, and eventually hung the sucka!
Here are the patterns, not as good as I would have liked but its a front so we should be okay.  :crossed:
Forward
Coast
GotMyYotaBack [OP]
  • Male Posts: 201
« Reply #56 on: Feb 02, 2010, 04:51:41 PM »
More....
I love clean parts!  8)
Jud
  • Scumbaggin
  • Male Posts: 3,067
« Reply #57 on: Feb 02, 2010, 04:54:52 PM »
How much backlash did you setup with Dan? Pattern looks "ok" as you said, but it looks a little shallow for my liking...
"bout tree fiddy"
GotMyYotaBack [OP]
  • Male Posts: 201
« Reply #58 on: Feb 02, 2010, 04:56:53 PM »
More....New Ride height!
I didnt even check to see if ft shaft is a CV? I suppose this wont be a problem, with duals and new cross member :turtle:
Front Shackle angle, I have the front spring hanger "tacked" in place and we put it about 1" further then flush with radiator support, I may be moving it back  :yesnod: We will wait til' the rear is self supported and make sure we know what the true stance is.
GotMyYotaBack [OP]
  • Male Posts: 201
« Reply #59 on: Feb 02, 2010, 05:03:46 PM »
6, and that was the issue, to get it any better I would have to take it lower and I didnt want to do that. I sure as hell didnt want to start over for the 4th time and it was getting late, Tyler and I were committed to getting it assembled and hung by Sunday. Its gonna get an ARB later, maybe I can take another stab at it then
Last post Dec 01, 2005, 08:51:10 PM
by rockscrambler
Last post Mar 28, 2006, 05:41:16 PM
by Shoyrtt
Last post Feb 22, 2008, 10:08:08 AM
by CrazyYota
Last post May 23, 2010, 01:28:16 PM
by IVrunner
Last post May 31, 2012, 09:01:07 AM
by Opias
