A new section for basic Q & A
Started by TacoRunner, December 29, 2009, 10:57:30 AM
TacoRunner
A new section for Mechanic based questions.
www.4WHEELUNDERGROUND.com
[email protected]
bigarms23
not just mechanic questions but all things
if your not sure this is the place to ask
trucha
ok..here is a Q? anybody...i just put a new flywheel, clutch, plate and presure plate under my 80 toyota 4x4...when is running it makes a sound that it wasnot there before, when i press the clutch pedal the sound goes away, can it be that I put the clutch plate backwards? help
SocalWheeler71
Depends how loud it is. Could just be the throwout bearing if it's not too loud.
bleakhorizon
i would say its the T.O. bearing, could be the pilot bearing also.. dont most clutch kits come with the T.O. did you put a new one on?
mine is sorta strange, only seems to squeak when the engine is over its normal op temp!!!
Those are some huge welds!
Tillamook, OR
Mtn. Toy
Have the same symptoms with a 98 Taco, after 20,000 miles still no problems :thumbs:
Was told it was the T. O. bearing.
TacoRunner
Quote from: trucha on December 30, 2009, 05:51:19 PM
Mine did the same thing once a pon a time. My pressure plate bolts weren't tight enough and allowed the disc to skip and chadder.
Did you torque the bolts down per the book. There is a pattern you follow (star).  I know the 3RZ stuff they require you to go torque to 14 lbs and then go back and in a star pattern torque them an additional 90*.
That could have been the Flywheel too, did you take that out and replace it or anything?
[email protected]
trucha
TacoRunner, I think u r on the money, the sound it makes is more like a chadder sound, it goes away when I press the ckutch pedal, flywheel, clutch plate and pressure plate was change and no I didnt use a torque wrench.... :nope:
SocalWheeler71
Pilot will only make noise when the clutch is released.
sabatoa1
I had the same problem so I pulled it apart and one of the prongs on my T.O. bearing was broken off. I say it has to be something with the T.O. bearing
1984 4runner buggy 22r on pane, duals, hydro assist, spool front, spool rear, 37x13x16 Creepy Crawlers.
http://board.marlincrawler.com/index.php?topic=89989.0
ronezrocky
going with T.O bearing gotta think parts made by the thousands are bound to fail at 1point QC only goes so far and we are all human
84krawler
im goin to have to say its the throw out bearing you should check the pilot bearing too
BHT12
What is the gear chart for a dual transfer case like.. how do you know what gear your in and how it means that  from 1st to 35th gear.. If that makes sense??
1984 4runner. Trailgear fronts, custom backs with shackles, 36 iroks, hi steer, hybrid 20+22r motor, full exhaust, lowsy weber, power everything, rear heat, power Antena,  sr5, altimeter,  back seat eliminator, tube bumper
1981 2wd long bed parts getter. All stock, sr5
1983 Toyota Sandtana Motorhome 4x4 Stock.
chicorider
i got 529s on my 84 yoda and i put 37s and my 1st gear still feels short. thinking i might be able to use 38s.
chicorider
about to add power steering on my 84. i guess there's some sort of bolt on mounting plate for the ifs box available for purchase? i guess i also need pump, resevoi,r and bracket as well. any ideas anybody?
