1980 Pickup - First Trail Carnage!
Started by birfection, December 24, 2009, 08:25:41 PM
REG535
sweet. i want to do that to my shocks tell me how it performs that way.
birfection
I think I got enough grease on this one
TITAN CRUSHER      http://www.youtube.com/watch?v=v6qnDVgWBSA
1980 Pickup: 22RE (bored 20 over, OS Valves, 261 cam, ported and polished intake/exhaust, Pacesetter long-tube header), L52 5 Speed, 6 leaf RUF, 63" Chevies, Hi-steer, 35 x 12.5 Maxxis Creepy Crawlers, Dual 2.28 cases, Detroit Front, Welded Rear, 5.29s
toyotaraskmt
haha. greasin the knuckles sure is messy. i'm gonna get to do it again here pretty soon.
i'm likin the truck.  :thumbs:
birfection
Quote from: zippo on March 05, 2010, 06:55:37 PM
Is that POR15?
It's a similar product called "Chassis Saver". It was $95 for a gallon. I've used about a half a gallon so far to paint the frame, axles, gas tank, skidplate, bumper, driveshafts, oil pan, leafs, and u-bolt hardware
birfection
Installed the front brakes today and ordered the material for my flatbed. Also picked up a Thrush Glasspack for $19.99-couldn't pass that up! I also cleaned the floor in my cab so i can paint it and then piece in some metal where the holes are. Going to get A LOT done this upcoming weekend.(Two of my friends and i will be fixing the cab and putting together the flatbed) I'll post some pics when we're done. I picked up some sweet(and comfy) 94 4Runner bucket seats for $75 at the junkyard. Welding the diff this weekend too, LOTS GOIN ON!!
birfection
Been super busy lately trying to work and get this truck done enough for the hillclimb April 3 and 4. Here's some pics of the many different stages thus far.
Cutting the rear bumper at the shop where my buddy works
birfection
#36
This bumper is 6 x 4 in steel(.25 wall thickness). Beefy stuff! Hoping to make it into an onboard air tank in the future. Check out this clean plasma cut for the receiver
birfection
Picked up the deckplate flatbed from the steel company. They cut the plate and broke the 90 degree angles that make the fenders. Here's a pic of it mocked up with the bumper too:
birfection
without the bumper:
birfection
We capped and ground the ends of this 1.5 inch square tubing for cross braces:
birfection
Time for a true Lincoln Locker!
birfection
Picked up some 1/8 inch 888 Rod designed for welding hardened metal. Used this to tack the spiders in place:
birfection
Finished of the locker with some 3/8 inch plate welded in place. The axle shafts are gonna snap before this ever breaks!
axled89
i love oregon wheelin.
CrazyYota
Quote from: birfection on March 05, 2010, 06:40:25 PM
the grease will come out the felts when you drive it. Ask me how i know.  :gap: Truck looks good. :biggthumpup:
Quote from: CrazyYota on March 19, 2010, 08:41:08 PM
not if the knuckle is set up correctly,  grease rarely comes out the felts, but when the inner seals leak :yikes:  then a mixture of grease and gear oil makes a nasty mess
CrazyYota
What do you mean by set up correctly?  when i rebuilt the front axle I installed the HD MC axle seals. About a month ago i tore it apart to install a hi pinion diff the grease was still clean? maybe is the type of grease i used? comes out the felts clean. :confused:
birfection
The bed nearly done before sending off for sandblast and black powdercoat :king:
birfection
Hi-lift mount up close:
birfection
picked the flatbed up recently. Sandblasted and powdercoated for only $150!! And it looks great. I've been REALLY busy doing motor work lately(discovered a timing cover leak yesterday and had to fix it for the Hillclimb this Sunday). Tires go on tomorrow, I'll post updated pics soon
4x4yota
looks good I like the design and the high lift mounts
Current:
Sold:
birfection
Here's a shot all done with the new meats :beer:
birfection
The light housing is stainless
P-DiseToy24
birfection
Took it out and played in the mud some
REG535
zippo
If you see it, its for sale.
birfection
Every time my rims get black from the mud, it makes me want to paint em black. I'm gonna do it this summer!
birfection
When these cleaned out on the road it was hailing mud!
birfection
Here's a pic of the most colorful 1st Gen door interior
