Ok so I'm looking into buying a 1991 Toyota 4x4 with IFS. I was wondering how much work would be involved in doing a straight axle swap?
Honestly..I think its pretty simple, just tedious work. It was really nerve racking doing mine, but that was the first real fab work i ever did.I would say the longest part was getting the axle rebuilt, and cleaned up to go under the truck.. Especially when its your first axle rebuild.Depending on what tools you have available you can get the ifs cut off pretty fast. When we did mine it took forever, but we did my buddy johnnys and used a sawzall (again) and we had the main points of the ifs cut off within an hour and just had to clean the frame up a bit.I would recommend reading the install instructions from marlin to get an idea of what is involved, and 4crawler has a great writeup on rebuilding the axle.You can get it done in a weekend if your really motivated.I would highly suggest having the axle COMPLETELY built and ready to go under the truck before you cut off the ifs. Just makes it go that much smoother/quicker.
Did mine in 3 full days of work, would never do it again, give yourself some time, do it in 2 weekends or something
ya deffinetly give yourself a spare time cause you'll run into dumb tedious problems, like for me the pitman arm, and the cone washers on the hub
Also it gets stressful. Better to take your time and do it right the first time.
And if you really need the truck DD, the SAS parts don't interfere with the IFS. So you could weld the front hanger on/Frame tubes on and then focus on the Axel. Then when your ready, Cut the IFS off, simply bolt the axle up and weld the shock hoops and PS box on.
People do that, but a lot of people want to put the hangar where they want it and have the weight of the vehicle on the springs to determine the shackle angle.
Come one people. Its not that hard. I don't even find it tedious or stressful. Just take your time and check everything. If you are good with your hands/and have done work like this somewhat before, you could, cut the IFS off/weld everything on day 1. Days 2 put everything together. Day 3 would be for fine tuning, odds and ins and taking her around town to show your friends. And if you really need the truck DD, the SAS parts don't interfere with the IFS. So you could weld the front hanger on/Frame tubes on and then focus on the Axel. Then when your ready, Cut the IFS off, simply bolt the axle up and weld the shock hoops and PS box on.
I think the difference here is, you can take two different approaches to doing a SAS. You can cut off only what is not needed, which makes the job faster, but leaves alot of excessive stock behind. Or you can take your time and start eliminating all that stuff and end up with much cleaner looking truck. Like the torsion bar brackets. Most people dont cut them off, and to do so you have to move lines around and out of the way, so its a pain in the butt. But in the end you are probably happier with it being gone and out of the way, plus it make future mods much easier.
Started by 98runner chevota Rigs For Sale
Started by toyotatuner Parts Wanted
Started by little eric Parts For Sale
Started by Duffil Rigs For Sale
Started by 3RZISUAMIGO Project Research and Build-Ups
