Author Topic: 3rz swap in 1991 Isuzu Amigo.  (Read 12169 times)
3RZISUAMIGO
  • Male Posts: 28
  • Member since Oct '09
« on: Oct 09, 2009, 07:31:03 AM »
got this isuzu amgio for free ( well sort of,  did the side job on one of my buddy car.  he didn't have the money so he gave me this amgio for the job)   Found a lot of thing wrong with it.  One  Head crack.   Two,  a lot of parts missing off the engine.   So Went to U-pull it ( auto wreck yard)   Was looking for Isuzu trucks parts.   Most of the parts are missing or had been taken  off.    Then I came across this 92 Toyota 4 runner.   What got my attention is that.  a five speed r-150.   I was thinking about swap a 3.0 in my amgio.   Well Guess what.  I went ahead and took the transmission with all the drive shaft and transfer case with it.  paid  150 buck for it.   Got home and look it up on the web about 3.0   I came across this website marlin crawler about 3rz bell housing.   so did a research.  and found myself a whole 3rz  from a wrecked Toyota Tacoma.  got the engine and ecu etc for $1000.00  Will Post  photo here soon.
« Last Edit: Oct 15, 2009, 06:55:23 AM by 3RZISUAMIGO »
*FFC*
  • Platinum Turtle Award
  • Internet Lassies
  • Turtle Points: 11
  • Female Posts: 8,265
  • Member since May '04
  • ~*Moderator*~
Re: 3rz swap in 1991 Isuzu Amgio.
« Reply #1 on: Oct 09, 2009, 07:33:13 AM »
Holy cow I'm jealous :drooling: I have an Amigo on Yotas. The main thing it's missing is the 3RZ (to adapt toyota trans, mainly)... I can't wait to see your build! I'll be following along  :beerchug: :beerchug:
Oh yeah, :welcome: to the board! Try posting in the new member section and introduce yourself :thumbs:
3RZISUAMIGO [OP]
  • Male Posts: 28
« Reply #2 on: Oct 09, 2009, 12:08:25 PM »
got my marlin 3rz bellhousing and Heavy Duty bearing cover plate and Heavy Duty Shifter Seats for my R-150.   Got to tell u it was cover with old grease / dirt.   using oven cleaner stuff to get all that junk off of it.   Had order all new seals for it also.   took everything apart.  replace the bearing cover plate and replace with marlin heavy duty one.  everything look great inside the transmission.   I dont know what I got when I got it from U-pull it.   It could be good or bad.  Lucky it all good.   I put everything back together.  Using honda bond (silcone) for the seal between the two housing.  ( i work at honda dealership,  the best stuff they use for honda stuff).   install new seals front and rear.   now it ready for install in my amigo.   Also Have to shop around for small stuff like starter,  alt.   That was missing from the engine.    found starter from local auto yard.   Went back and found me a alt off from 1993 Toyota Previa.  it look pretty close.  so bought that.  only paid 15 buck for it.   Went to auto parts store to have it tested.   it test really good.   came home and try it on my 3rz.   it look like it lined up right.  on top where bracket.  I had to add spacer.  which is no big deal.
3RZISUAMIGO [OP]
  • Male Posts: 28
« Reply #3 on: Oct 09, 2009, 12:12:17 PM »
also have to get new flywheel.  it used to be auto.  also got new clutch.  I took stuff apart on my amigo to get ready.   I had to ask my buddy to set up a day to do the swap.  He is a welder.  had helped with my other project in the past.   Very hard worker.
3RZISUAMIGO [OP]
  • Male Posts: 28
« Reply #4 on: Oct 09, 2009, 12:16:27 PM »
in the future my plan is to sas.   use toyota front and rear.   I know that isuzu gear ratio different.  also u can find aftermarket gear set.   bigger tires.  not sure what size yet.
86rustbucket
  • Turtle Points: 45
  • Member since Jun '09
« Reply #5 on: Oct 09, 2009, 12:33:40 PM »
here man tell me what u think of my pile o junk that will be your 12 th post
http://board.marlincrawler.com/index.php?topic=61196.0
3RZISUAMIGO [OP]
  • Male Posts: 28
« Reply #6 on: Oct 09, 2009, 12:39:19 PM »
just a test to see if my photo showed up.   I am at work so this is my other car I had build in the past.  So all my photo for amigo is at my other computer @ home.
3RZISUAMIGO [OP]
  • Male Posts: 28
« Reply #7 on: Oct 09, 2009, 12:45:53 PM »
I went home for lunch today and try to post it  on here.  I was so bummed out that it wont let me post it.  so I got back to work.  SO will try again tonight.
86rustbucket
  • Turtle Points: 45
« Reply #8 on: Oct 09, 2009, 12:49:27 PM »
resize the files to smaller than 75 kb
3RZISUAMIGO [OP]
  • Male Posts: 28
« Reply #9 on: Oct 09, 2009, 12:54:54 PM »
how do u resize it?
86rustbucket
  • Turtle Points: 45
« Reply #10 on: Oct 09, 2009, 12:59:45 PM »
im a computer dummy but i down loaded picasa from google its a pic program and its free    just google free picasa download
once u have it you can send your pics to it and do whatever u want with them
*FFC*
  • Internet Lassies
  • Turtle Points: 11
  • ~*Moderator*~
« Reply #11 on: Oct 09, 2009, 02:29:44 PM »
The toyota swap was fairly simple - it's the wheel base that'll bite ya in the :moon: . I use a stock 2nd Gen Toy front driveshaft in the REAR of the Amigo, and a huge front. You're doing it right though - do the engine swap first, then do the SAS. The steering is a little pain in the butt, but nothing that can't be jimmied to work.
3RZISUAMIGO [OP]
  • Male Posts: 28
« Reply #12 on: Oct 09, 2009, 07:13:43 PM »
here is my amigo.  before the swap.  also 3rz on engine stand.  R150 on the floor
3RZISUAMIGO [OP]
  • Male Posts: 28
« Reply #13 on: Oct 13, 2009, 08:00:14 AM »
Got the oil pan, oil pick up tube and  oil dipstick from T100 2wd.   install those on there.   also inside the engine doesnt look too bad.     Took the Isuzu over to my friend's house.   we started to work on it.   Took the body off the frame.  It will be a lot easy to work on.   Went to parts store to get some exhaust pipe,   Got aftermarket cat,  muffler,  some bending pipe.   will post some picture here soon.
*FFC*
  • Internet Lassies
  • Turtle Points: 11
  • ~*Moderator*~
« Reply #14 on: Oct 13, 2009, 09:09:29 AM »
I :love: progress :beerchug:
3RZISUAMIGO [OP]
  • Male Posts: 28
« Reply #15 on: Oct 14, 2009, 05:10:04 AM »
got the old engine/ transmission off with no problem with the body off.   u can see we already custom our own engine mount plate.   this was all in one whole day.
3RZISUAMIGO [OP]
  • Male Posts: 28
« Reply #16 on: Oct 14, 2009, 05:13:08 AM »
got the body back on the frame,  to make sure it fit between the engine and firewall.  found that the transmission hit the bottom of the floor board.  so we made a 2 inch body lift.   also got all new hardware.  all the bolts that are rusted away.  so this was a good time to replace the body bolts and add two inch lift.
3RZISUAMIGO [OP]
  • Male Posts: 28
« Reply #17 on: Oct 14, 2009, 10:14:07 AM »
I am using stock isuzu amigo speedo cable,  found out that it fit nice, it screw right in.  look like same company make em for some reason.   but not sure about that.   I am using stock tacoma power steering pump.   Found that my old 2.6 power steering pressure hose and return hose are on other side of the engine.  So I went to wreck yard and found out that Isuzu 3.2 V6 are on other side.  So I took that.   Swap the hose.   the hole on the pressure hose that hook up to the tacoma power steering is a bit too small.  Had to drill it a out a little.  and it fit.   Now did the wiring job.   I am using stock tacoma wiring.   so I can plug in the ecu.  the only problem I have is the one plug for ground and power.    It took me three days to finish it up.
3RZISUAMIGO [OP]
  • Male Posts: 28
« Reply #18 on: Oct 14, 2009, 10:19:59 AM »
Now trying to figure out what to do with the driveshaft.  I did the measurement.  found that front and rear are almost the  same length.   So I took the isuzu driveshaft and toyota driveshaft and took it over to driveshaft shop.   Told em how long I want it and which one go to which.    They got it done like in one day.   Found out it cost me 150 buck each.  :willynilly: I thot it would cost me around 50 to 60 buck.   Oh well.
3RZISUAMIGO [OP]
  • Male Posts: 28
« Reply #19 on: Oct 14, 2009, 01:49:25 PM »
I had been thinking for awhile,  I was thinking of putting TRD supercharge on it  or this turbo kits from www.koracing.net/viewproduct.php?folder=103&product=479  Does anyone here do a turbo on 3rz before.  I know I had seen 2rz drag car with big turbo set up.   But what about low boost on a 4x4 truck?
thegoofster21
  • Male Posts: 1,644
  • Member since Mar '08
  • HIT IT HARD!!!
Re: 3rz swap in 1991 Isuzu Amigo.
« Reply #20 on: Oct 15, 2009, 08:14:56 AM »
looking good for sure. as for the turbo i my self have not seen one on a 3rz but that thing would haul  :moon:
Any guy who takes his woman wheeling enjoys her. A woman who is owned is left at home to cook, clean, and keep beer cold. So if this offends you you should stop looking and go have some tacos.    :rofl2: And a beer. If your old enough.   :beerchug:   :beer:
04 Tacoma 33s http://board.marlincrawler.com/index.php?topic=61454.0
jmoffroad.com
3RZISUAMIGO [OP]
  • Male Posts: 28
« Reply #21 on: Oct 15, 2009, 11:02:07 AM »
Here is a picture that website had done on a 3rz taco truck.  here is the pix.  check it out.  www.koracing.net/gallery.php?folder=49
*FFC*
  • Internet Lassies
  • Turtle Points: 11
  • ~*Moderator*~
« Reply #22 on: Oct 16, 2009, 02:36:49 PM »
This thing's comin along very nicely!
  • 96ZJ v8
  • Turtle Points: -415
  • Male Posts: 4,823
    • Buy me a drink
« Reply #23 on: Oct 16, 2009, 02:47:05 PM »
I want to watch!!! holy crap dude
3RZISUAMIGO [OP]
  • Male Posts: 28
« Reply #24 on: Oct 17, 2009, 06:53:14 AM »
So far What parts I had use to make my amigo to work.   I am using 3.SLOW clutch fork,  slave cylinder,  custom clutch line.   I am using my amigo stock clutch master cylinder.  for Fuel line,  I had found a 97 4runner.  took the whole fuel line out.   Had to put it in to make it work on my amigo.  But got it to work.   Also didnt have  3rz cooling fan.   So I found one from 3.SLOW 4 runner at u- pull it.    Came home and try to put it on.  I realize it dont fit.   SO what I did was trim the back fan where it hit the pulley.  I trim it  till it flat even.   Will post a picture of that.   Got the wiring all done.   Got it fire up.   Yes I do have some little bug.   working on that to get solve that.   Clutch work great.   Cooling fans no problem.
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #25 on: Oct 17, 2009, 07:07:59 AM »
:beerchug: atta boy! :gap:
cant wait to see it done
86rustbucket
  • Turtle Points: 45
« Reply #26 on: Oct 19, 2009, 12:21:57 AM »
 :popcorn:
3RZISUAMIGO [OP]
  • Male Posts: 28
« Reply #27 on: Oct 26, 2009, 09:49:25 AM »
here is the 3rz engine sitting inside the amigo engine bay
Last post Feb 26, 2006, 08:58:38 AM
by wheelinyotagirl
Last post Jun 21, 2007, 12:43:55 PM
by *FFC*
Last post Aug 02, 2007, 06:31:04 PM
by wheelinyotagirl
Last post Nov 18, 2009, 03:29:10 PM
by Travis H
Last post Feb 17, 2011, 07:49:27 PM
by toe
