Corax's 4runner
Started by corax, September 06, 2009, 07:25:15 PM
corax
I built my '88 more as an expedition rig, trying to make it good at a bit of everything
Aug '08 Big Bear, CA (Dishpan Springs)
Sept '08 Yosemite CA
Oct '08 Trinidad, North Cali - amongst the BIG trees
Oct '08 Crater Lake, OR
Jan '09 TTORA @ Rausch Creek Offroad Park, PA
June '09 TTORA EC4RJ @ Rausch Creek
1988 4Runner
-3.0L 7MGE Supra engine swap (200 hp stock, inline 6)
-Port & Polish on the cyl head with ARP head studs
-MSD 6A Ignition, MSD Blaster 2 coil  and MSD 8mm wires
-2.5" mandrel bent exhaust through a stainless Flowmaster Delta 50 muffler
-OME Dakar rear leafs, Marlin Crawler U-Bolt flip kit, Bilstein 5150 remote reservoir (177/60 or soft valving), urethane bumpstops
-T-100 caliper / rotor brake upgrade, T-100 1 1/16" Master Cylinder, removed LSPV and installed Wilwood manual proportioning valve
-home-fab front bumper, rear bumper with receiver, lower control arm brace, idler arm brace
-Toyota LSD front differential swap from an '83 Celica Supra
-4.56:1 V6 center sections front and rear w/ 32x11.5x15 BFG A/T KO tires on alloy's (soon 4.88s w/ elocker rear + 33x10.5 KM2s)
-Marlin HD W56 trans
-Hannemann front fenders
-Ford T-Bird Turbo Coupe hood vents
-110,000 candlepower driving lights (aircraft spot beams)
-rear driving lights
-SR5 gauge cluster (tach, oil press, voltage), added engine vacuum gauge
-Cherokee CM-10+ CB peaked (10w), tuned, and able to transmit on 10M, 11M, 12M bands (CB is 26.965 MHz -> 27.405 MHz, I have 23.815 MHz -> 30.555 MHz)
-Yaesu FT-2800 2meter 65W Ham radio (135MHz - 173MHz)
'-89 Celica All-Trac Turbo seats
-NWMP 14 gal aux tank w/ electric transfer pump (no gravity feed through the drain plug)
My Garage Thread
My cross country trip thread <- the wife drove the 'runner pulling a 3,500 lb trailer 4,000 miles, I was driving the RV
'88 4runner SR5 - 3L 7MGE swap - Marlin HD W56 - 4.88 LSD and e-locker - 33x10.5 KM2's
Garage Thread
starrunner
BEER PONG! you can play me, but cant beat me
PA_taco_13
:welcome:    :beer: for a sweet rig.   You come to PA often?
learn the hard way
"my dixie wrecked"
east coast crawler
corax
Quote from: pataco13 on September 06, 2009, 08:07:50 PM
I'm hoping that's a Yuengling :talkingn: Yep, I'm living in eastern PA for the moment (born and raised, except for the last few years), might be relocating to Wild and Wonderful WV sometime in the next year or so
Garage Thread
Yota-Freak
hey sick rig man  :biggthumpup: welcome to marlin. i noticed you had hood vents? do those things really work for cooling the engine? i heard that they can cool it by 45 degrees...im thinkin of getting some cuz i run really hot for some reason...just wanted to know if they actually work. thanks.
Sean
corax
Quote from: Yota-Freak on September 06, 2009, 09:55:38 PM
Sean
I wouldn't believe any claims for a specific temp reduction because it's all very dependant on where the vents are, how fast you're traveling, ambient temps, etc.  From what I can tell, they work.  In the winter, the spot above the vents are the first to melt through and last winter when I popped my radiator hose I got early warning via coolant spray on the windshield :)  Never actually measured the underhood temps though to verify how effective they are.
The vents I used are from a Ford T-bird turbo coupe, got them in a junkyard for < $10.  Take a walk through your local bone yard, there are usually plenty of late 80s/early 90s t-birds in there.  If you face them rearwards, they pull air out of the engine bay which should help pull air through the radiator.
Garage Thread
Yota-Freak
yeah thats a good idea....i dont want em for looks...my truck just runs really hot...specially being black bedliner which sucks in heat and keeps it in the engine bay....and its like 100plus here daily...anywho thanks for the input dude. should help my engine out quite well :biggthumpup:
Tallchevy
87 4Runner redo
4RunnerChevy
Glad you finally made it over here Keith :welcome: from Santa Cruz
corax
Quote from: 4runnerchevy on September 07, 2009, 04:41:10 AM
Hi Kev!  I'd been lurking for long enough, now I'm trying to find out some info so I can get my elocker regeared, built and installed
Garage Thread
luvyota
 :welcome: sweet rig do you have any pics of the engine i would like to see how you got it to fit :inthedark:
luvyota
corax
Quote from: luvyota on September 07, 2009, 08:18:22 AM
everything was bolt-on except for the radiator (although I have heard of people running a Toyota V6 radiator and making it work, not sure if they used the 5MGE engine mount brackets though or welded their own)
7MGE swap notes and pics
final radiator install <- this was years after the initial engine swap
Garage Thread
bigarms23
welcome from truckee glad you found marlins board
46&2
 :welcome:
Very nice rig I am digging the 7MGE swap.  :beerchug:
NoPower
Very nice runner. Love the engine swap. Got any pics of the engine swap? Was it a pain in the ass to swap the engine? I have an 87 turbo auto 4runner but I'm thinking about swapping it out for some thing else :thumbs:
yjay
That seems like an ideal motor to swap in. Any idea on the mileage?
Nice clean ride  :thumbs:
22re Daily Driver
http://board.marlincrawler.com/index.php?topic=56568.0
91 4Runner-R151f, MC07,23 spline duals, Marlin 1200lb clutch, 85 Front axle, Leaf swap rear, Yukon 5.29's, BFG KM2 35's, Detroit, OBA, 280k
corax
Quote from: NoPower on September 07, 2009, 03:52:34 PM
Quote from: yjay on September 07, 2009, 05:02:28 PM
I get 19.5 mpg on road no matter how I drive it - highway, stop/go in town doesn't matter, and I'm not generally light on the throttle.   Coming cross country pulling the 5x8 enclosed trailer (~3500 lbs) we got 17 mpg. The only time I ever measured offroad mileage was in Big Bear, CA and it got 15 mpg crawling around and idling
Garage Thread
 :welcome: to the board, looks like a capable rig you're building there.
luvyota
Quote from: corax on September 07, 2009, 01:01:51 PM
looks good man i like the radiator
luvyota
jeff94runner
"Keeping the heavy light the heavy can be handled"
axled89
nice platform ,we like 4runners.
i love oregon wheelin.
PA_taco_13
hey man how do those 4.56's treat you on the back mountain roads of PA? i have been thinking of re-gearing my truck and have been stuck between 4.56's or 4.88's   but i'm only gonna run 33's   soooo whats yer  :twocents:     thanks in advance  :thumbs:     :beerchug:
edit:   just saw you wanted to change to 4.88's  whats the down fall of the 4.56's   you wanna go bigger  tires  :dunno:
learn the hard way
"my dixie wrecked"
east coast crawler
axled89
corax
Quote from: pataco13 on October 02, 2009, 04:12:50 PM
hehehe - just got 33x10.5 KM2's and I'm gonna test them out next weekend at Rausch Creek (supposed to be raining, so the muck factor should be pretty good)
with my 32's the 4.56 gears were perfect - speedo was even correct.  Now with the 33's, it's just a bit slower than I want + I do tow with this, so I'm thinking 4.88's will put me right back where I want to be.  Just got my 4.88 front diff (need to swap the LSD over), next is a  set of Yukon gears for the back and a solid pinion spacer - still not sure if I want to set these up myself or not.
Garage Thread
PA_taco_13
 :thumbs: thank you very much for the input :yesnod:    thats leading me to think i'm going to like the 4.88's better.   have fun at rausch creek next weekend, with this week ends rain and if its going to rain next weekend the MUCK factor will be way up  :king:
:beer:   i hope to see you on the trail one of these days i would love to have a look at the runner and share some stories  :beer:
learn the hard way
"my dixie wrecked"
east coast crawler
axled89
corax
Quote from: pataco13 on October 18, 2009, 02:22:57 PM
Yeah, you won't regret 4.88's - much more fun with "smaller" tires + it'll give you a bit of room to grow in tire size
Garage Thread
MR.FULL-FORCE
welcome to the site...nice runner...
corax
Quote from: corax on October 18, 2009, 12:47:11 PM
. . . . so I'm thinking 4.88's will put me right back where I want to be.  Just got my 4.88 front diff (need to swap the LSD over), next is a  set of Yukon gears for the back and a solid pinion spacer - still not sure if I want to set these up myself or not . . . .
Just ordered for my e-locker 3rd :D and I'm gonna have the guy that sets up the rears in my friend's small block modified help me set these up.
I towed my 3k lb towable backhoe down to WV and back last weekend and didn't notice any power loss with the 4.56s and 33s, but my old front and rear diffs will be up for sale in a few weeks anyway
Garage Thread
4RunnerChevy
When you gonna solid axle that thing ?   :shake:
